Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Daily Driver Moog Coil Spring Selection help
Old Jun 25, 2012 | 03:30 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
ive just started researching about coil springs and suspension setups
i autocross here and there and my iroc is a daily driver
i have eibach sportlines that are way to soft and really disliking them and car pushes alot unless i stomp on gas or do some crazy braking
i also have lcrb and control arms sway bar end link poly and im running 10" wide wheels all around
as for what i want is a neutral feeling car with a bit of oversteer. to better control car with trottle then doing crazy hard braking to get car to turn in
im going to be getting konis with the new springs
so im woundering from guys who use moog springs and autocross what would be a good choice i want to cut them to get the same stance i have now from ground to fender is 25" front and rear is around 26" so prop need to cut a coil or more and i was reading that when you cut springs it increase the spring rate
just looking to increase handling as to compared with sportlines and autocross my car
thank you
Old Jun 25, 2012 | 04:00 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Daily Driver Moog Coil Spring Selection help
was thinking around 800 front 200 rear ?
Orr89RocZ
Apr 25, 2016 08:28 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
TheExaminer
Aug 25, 2015 07:34 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
86White_T/A305
Aug 17, 2015 12:16 AM
