Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
92 z28 first time at track
Old Jul 6, 2012 | 11:12 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Taking the camaro to my local 1/8th mile track tonight for a bracket race event should be alot of fun. Will be the first time ive had this car down the track so im not sure what to predict. I wanted to get a run in with the stock 2.73 rear and i plan to go back on the 22 with a 3.42 gear and aluminum drums and driveshaft. Right now the car has 3in cat and catback vette servo air foil gutted air boxes bumped timing lowered lcarbs and tubular poly/rod lca and panhard rod. Ill most likely be running on my gta wheels with my nitto drs since this track is famous for having awful track prep. would be tickled to pull off a 9.5 run but i have my doubts plus its right at 100eg here today lol. ill post my results and hopefully a video or two.
Old Jul 6, 2012 | 10:55 PM
Screamin86's Avatar
Re: 92 z28 first time at track
Well ran a best of 9.82@70mph with a 2.1 60'. The drs hurt me
More than helped I believe though since the track was actually pretty decent from how it's been in the past. Was 97 deg out when I ran tried to figure out the da and came up with 4168. Track is right around 1200 elevation. Plan to go back on the 22 with 3.42s and see if they help. Car seemed to bog prett bad down low on the launch.
Old Jul 6, 2012 | 11:13 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
what size is your motor what all mods have u got done to the car its it auto or stick
Old Jul 7, 2012 | 07:15 AM
Screamin86's Avatar
305 tpi lb9 motor is stock other than 3in magnaflow cat and catback. Auto with vette servo 2.73 posi rear and suspension mods.
Old Jul 7, 2012 | 08:47 AM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
for a 305 that time is pretty dang good i thing at a 9.8 ive have a 87 camaro also 305 tpi i could only get it to run a 10.6 at 65 so be be pretty happy what your car is runnin
Old Jul 7, 2012 | 08:52 AM
Screamin86's Avatar
Ha initial timing at 8deg stock fuel pressure with walbro 255lph pump nitto drs at 20lb. The fastest run it hooked good but got loose a little hitting 2nd did no burnout that run the next two runs I spun enough to get dirt off tires hooked good on launch and down the track but got 2.3 60' both runs and a 9.9 and 10.0. Plan to go back in a few weeks with the better gears and aluminum driveshaft and drums.
Old Jul 8, 2012 | 10:34 PM
Screamin86's Avatar
Azrael91966669
25
Jun 20, 2017 04:04 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
