won my first heads up race tonight
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: won my first heads up race tonight
I've always been a fan of all motor street/strip cars but I do understand the limitations, you can only go so fast before its no longer a street car. You need a power adder to be a player in any type of heads up class unless you have a huge displacement big block.
If I was going to do a power adder it would be a pro-charger. I like the simplicity of a pro-charger and the power comes in gradual. There are some really nice bolt in pro charger kits that make it simple and clean. I like turbos too but all that plumbing creates heat issues and gets in the way of everything. I've seen turbo cars where the most simple maintenance task is a huge pain because of plumbing. Not all of them are that way but most seem to be quite difficult to work on. Several of my friends run nitrous and are always trying to talk me into running it because its the most cheap and easy way to go fast. They tend to break more parts and aren't nearly as consistant which keeps me from even thinking about going that route.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Procharger would be awesome, but so expensive....
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
I've had my Zex plate kit for over 6yrs now, never broken anything and is very consistant. I guess I'm just lucky, but I love my set up.
A forced induction/nitrous system is a fast track to going faster.Cheap??. Well we used up a bottle in four runs and use 114 race gas with it.That is using the bottle very conservatively.Maybe on the button .002 in the middle of a run.At the end of the day it gets expensive.
Yeah I read about pro-charger not needing to have special internal engine parts.If your going to build a blower engine,than you going to cam it for it,have forged pistons,rods,crank shaft,compression ratios for it too and well heads built for it as well and might even need to copper O-ring the cylinders for it.Also your going to gear for it too.Haft way doing it isn't a good answer.You either do it right or not.Cheap??. Nope.
Engine: 7.0L
Where did you get that I'm half doing it? I'm not going to type out all the details of my plans but I have done my research.
Your one of the racers that know what's up.Sorry if you took my post wrong.I didn't intend to offend.
Engine: 7.0L
since "tone" cannot be read...be more specific and you'll **** less people off
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
looks like whatever i'm going to do will need to take the back seat. i'll get some appropriate tires and try to do this more often, but my wife and i are disagreeing on the power adder situation. we need to figure out what will work best for us and then go forward. this is about us having fun as a couple, and i don't want to do something that will cause stress, lol
lol! i like that one.
mine is pretty understanding, and knows i like messing with the car junk. i put my gta in mothballs for nearly 3 years now so we could work on the house and get ourselves in a little better financial position. the past month or so i've been scrounging some stuff up to get the car going again, and she's been ok with that. got a glide for it yesterday. switching over from the th400 to keep it off the bumper.
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
Not trying to thread jack , but a buddy of mine gave me this zex plate nib. Having a hard time finding an entry level kit that doesnt come with a plate because i already have one. Any suggestions?
Yep.Go to the Drag Racers Auction held in Indy over Thanksgiving Weekend.Tons of parts to finish that up.
Centri-type chargers come in pretty quick too when pullied up, but they too can be boost controlled pretty easily.
B4C - all you need is a couple noids, couple lines & a few jets. I don't know of any kits that way, but you can get those pieces reasonably enough from places such as Induction Solutions.
91_B4C_RS you could also look at this PDF file and buy whatever jets you need for that ZEX plate from Comp Cams. I believe you can only use their jets for their plate, so be careful. You also can use it as a guide for whatever jetting you want to run. I've had my zex plate for 6 yrs now and I love it. Here are the instructions.
http://www.jegs.com/InstallationInst.../249-82040.pdf
^ That's actually a reasonably close stating point for jetting. Not nearly as fat as older tune-up sheets, even a bit better than many other newer sheets.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Hey matt...sounds like you got that lil lsx rollin down the track.
Procharger is the best IMO..but thats if youre always using it racing. For the price ..if youre driving a lot and running this event once in a while...use a 150 shot and drive home.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
There is a bolt on procharger kit for carbed LS I cannot wait to try out actually.
Engine: 7.0L
i see yours is flying now based on the sig pic! what's that little 355 got in it to go 133mph n/a?
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Well then just go for it....haha
What are you waiting for???? Nobody said racing was cheap.
And my 355 is nothing special..brodix heads..erson cam...and it went 10.20 with a qjet. Lol im sitting #1 in points right now in my local street car class.
I like the turbo idea...but blower cars are dominating right now!!
Engine: 7.0L
what does it weigh man? still street driven?
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
It weighs 3100 with me in it. It was 3000 but had traction issues so i added 100# to rear to cure that..now it 60' s usually in the 1.39-1.40 range.
Unlike you i stopped street driving...it has an 8.50 moly cage and lightweight th350 trans w/ 5300 converter...4gallon fuel cell...so its not a streetable ride anymore. Lol
I like your lsx combo though and i do miss driving from time to time.
i HATE taking this setup out of the car for turbo's, but i guess i'll go ahead with it.
355tpipickup
Aug 25, 2015 12:54 AM
