Harness Bar
Car: 1989 Iroc Z L98
Harness Bar
Hey guys,
I found some cool options for 4th gens for harness bars, I just wanted to see if I can run one and pass tech for NHRA. Here are a few I have found:
I realize something would probably need to be fabbed for it to fit my car, I just don't want to finish it and find out it's illegal.
Basically, I have plastic Summit seats due to being 6'6" and my head touching the roof, so now I would like to run 5 point harnesses at the track.
I have had an 8 point cage before, and do not want one in this car. Thanks in advance!
Re: Harness Bar
No reason for it to be "illegal" but as far as tech is concerned it's not going to be any different than a car w/ stock seat belts & no roll bar.
The first one I don't really understand the point of, when you could easily have run a bar straight across near the rear speaker locations. Would have been more solid and either way the rear seat looses what little function it ever had. - The second one I see the theory of being able to fold it back & still utilize the rear seat on the street, but honestly to me it looks more like a ***** show than real function.
Re: Harness Bar
I get what you guys are saying, here is my old car with an 8 point:
I feel like I did the roll bar thing, now that the limit is 11.49 I just want to run my belts the proper way.
I think what I would do, if you look at that first picture with the single bar. I would like something like that, but more easily removable and would only run it at the track. On the street, I would just run lap belts. That is what I used to do when I had my 8 point cage.
I wish you could safely floor mount the belts, then I wouldn't even be looking at a harness bar.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Harness Bar
As for alternative to a cage shoulder bar front seat shoulder harness mounting points.
Re: Harness Bar
Ok so I have a question, 5 point harness and fire jacket are 11.49 or faster correct? Is there a rule against running a lap belt in my vehicle running 11.50 or slower, if I choose to run just the lap belt from the 5 point harness?
Re: Harness Bar
I don't think the harness bar is a bad idea, just think I would do a more straight forward set-up than those you posted pics of. A set of brackets that bolt in somewhere around the rear speaker holes and a bar bolted across between them; would still be simple enough to make removable if you wanted re seat access/useage too.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Harness Bar
The point of that bracketry is to make the bar easily removable and so that you dont put a bunch of holes in the car. Its for the weekend racer who wants to maintain stock appearances. If they wanted to Im sure they could just weld a cross bar or mount one somehow and get rid of hte rear speakers and be done with it but it's just a way to have the benefits of the harness without being all "because racecar!" about it.
I did find this, though...
http://www.andysautosport.com/chevro...h90000037.html
The fourth gen bars will not fit our cars?
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Harness Bar
a 5 pt isn't required till a roll bar is, so what is the point of this? 5 pt harnesses are a pain to use...if i didn't need them, i wouldn't have them.
Re: Harness Bar
My thought was to run the lap belt portion on the street, and put the harness bar in at the track.
Am I crazy?
Car: 1992 Camaro RS
Re: Harness Bar
From what i gather, the vast majority of harness bar users are autocross people, or people who go to track days that don't require full cages. So, basically, purely an exercise in holding you in place during corners, not for rules legality.
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
Billy Decker
Sep 4, 2015 03:46 PM
. I want aftermarket belts but no cage this go around, eh it's a paradox I guess.
