Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
chasing a problem
Old Oct 2, 2013 | 12:11 AM
85SILVERBULLET1's Avatar
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
chasing a problem
I was out driving the firechicken a month ago and have had some problems since the drive. The problem started after a tire burner. Mid way through the burnout the car lost power almost like it dropped a cylinder and then hooked up.usually this car will spin untill I get out of it. As I pulled to a stop I noticed at least a 300 rpm drop from normal. No weird noises, puffs, bangs, or rattles. Car has felt low on power since.
Since the initial problem I have changed plugs, checked all wires, inspected and run valves. Checked initial timing and temped headers. The only odd thing I have run into that I felt was was a little off was the header temp. Number 3 and 7 seemed a little cold. Num 3 got to 120 ish and number 7 only got to 100 ish. All other cylinders were 200 to 300 degrees.
My next check is going to be a compression test and then to clean and inspect the carb.. any ideas would be great ad this is really starting to frustrate me. Thanks guys.
Old Oct 2, 2013 | 07:36 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: chasing a problem
I would do the compression test and see how the cylinders compare to each other.
Old Oct 2, 2013 | 10:50 AM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Transmission: built 700r4
Axle/Gears: 373
Along with the compression test do a leak down test.
Old Oct 2, 2013 | 09:48 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
you can also pull your valve covers and check for bent push rods, like on the intake valve in #7 cylinder.
Old Oct 3, 2013 | 12:28 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Ditto on pushrods
Old Nov 12, 2013 | 01:58 PM
Car: 85 Trans Am
Engine: 383 ci
Well I kept digging and finally found my msd pro billet dizzy to be the culprit.... Here is a pic.
Old Nov 12, 2013 | 07:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Interesting. I wonder how that happened? Any chance of getting warranty on it?
Old Nov 13, 2013 | 10:51 AM
Car: 85 Trans Am
Engine: 383 ci
I am going to send it to msd but it looks like 1 year is all u get. It looks like casting flaw
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
