Got front coil overs? Come on in!!
Hey guys, looking for a starting spring length and rate for aluminum headed small block using a 2" drop spindle and strange mustang struts. Glass hood and no accessories other than an Alt if it matters. Also relocated bat and no front bumper. Tried to
but couldn't really find anything. Thanks in advance!!
but couldn't really find anything. Thanks in advance!! Last edited by JesasaurusRex; Oct 15, 2013 at 12:34 PM.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Got front coil overs? Come on in!!
might be worth a call to racecraft or pa racing, lol.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Give me a call I've run the racecrafts on two thirdgens
You guys are miss understanding me. I JUST need the springs, everything else has been purchased (double aa performance stuff). I live pretty close to summit racing which is why i didn't order the springs when i ordered the rest of the stuff. Makes it a lot easier to return if I get the wrong one. Just looking for length and spring rate, not who i should buy it from
Engine: 7.0L
well, i was saying, call racecraft to buy your springs through because they will give you the tech advice based on real world results. you can buy just the springs through them, lol.
Car: 82 Z-28 (Cert 8.50)
Engine: 416 LS3 / 1050cfm
Transmission: Powerglide w/brake
Axle/Gears: 9" 4.86, 4-link
Jason @ PA Racing said I needed 14", 175lb springs when I got my setup from him......All aluminum LS3 based motor.....might be a good starting point or maybe 200lb I would say.....you have a cast iron block
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
I will just give my opinion and its just that.. I have a 91 bird and though I have lightened it pretty significantly when I used the 14" 175 hypercoils they were too stiff. They didnt compress very much and couldnt even get the car low enough. I am using the racecraft cc plates mustang strange struts with strange coil over kit. I also used a set of 150 on it and seemed better but pulled the motor and started a rebuild before I got very far with it. My car had a alum headed sbc.
yup , got a few other misc things layin around too but too many individual pictures. Don't feel like asking the wife to take a group photo since i already get yelled at for all the packages that she has to sign for
Engine: 7.0L
:drool:
i just sent Jason my first installment at PA Racing for my new k-member, a-arms, coil-overs, CC Plates, and billet ls1 mounts
hoping that sunday will be a successful day for me at the swap meet and i can get the rest to him. i'll still be running lakewood 90/10's though
What's the part number for those Strange struts? Single or double adjustable?
Terrell351
Jun 13, 2021 01:13 PM
TA8487
Aug 11, 2015 09:02 PM
