what gears and tires should i run
I am building a s-10 with a 385 stroker chevy I am building the motor with -10cc dished pistons and a .489 .520 lift duration @ .050 230/240 advertised duration 280/290 lsa/icl 110/106 and aluminum heads 2.02 1.60 valves and 64cc chambers 210cc runners for a compression of 10.52:1 and running 1.6 S.S. roller rocker Weiand 6500-1 pro street supercharger kit and a NOS fogger set at 200hp with a 1420 dominator 4500 carb. ok what would you suggest I run for gears and tire size and I will be running this on the street too I was going to use a GM10 bolt rearend thank you very much for your help
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: what gears and tires should i run
For best 1/4 mile performance, a combination that gets you across the finish line at or just after you reach your maximum rpm.
I doubt the S10's 7.5" diff will survive.
Start at the back and move your way forward. Build a proper diff, upgrade the transmission and driveshaft. Finally build the engine. Stuff the tallest and widest tire possible under the fenders then adjust the gearing to get the best performance.
Car: BUILDING 1985 HARD TOP T/A
Engine: sbc
Transmission: stick
Axle/Gears: GM
If it's for a third gen 29x10.5 D05 wrinkle wall
Car: 85 Camaro Z28
Engine: 400 SBC .040 over bore
Transmission: TH350 (TH400 on the way)
Not to be insulting here, but I'm wondering if you have the best cam for your application. Your lift numbers seem a little low for the best power so I'm just curious if you consulted a cam manufacturer to help you select one. Regardless of that, I think you've got a strong combination in your hands just wondering if there's a bit more power you could gain. Alright now on to tires. Wish I could help you out with the appropriate size for your application, unfortunately I don't have experience with an S10. I will tell you that it is possible to go too big. The bottom line is you need a tire big enough to hook hard and stay planted. After that point, however, if you keep going up in tire size as a way of changing your final gear ratio (bigger tires to give you more top end) you'll put additional unnecessary stress on the car (or truck). Once you get a tire big enough to hook, it's better to change your rear gear to cross the traps at the appropriate rpm. Getting your suspension setup right is every bit as crucial so you're not trying to overcome a bad suspension with bigger tires. Unfortunately, my method has always been some trial and error with tires. Best of luck and I sincerely hope someone can give you an actual size that works well for you instead of all the theory I just did.
BOTTLEDZ28
01-31-2016 01:20 PM
