Power steering overheat 2X
Car: 1989 Formula 350
Axle/Gears: 3:23
I've converted my 89 Formula 350 over to a Champcar / LuckyDog road racer.. So far I've run 2 races and melted 2 power steering pumps, the second at Buttonwillow Raceway in spectacular fashion in excess of 300 degrees. For my next race I've done a pulley underdrive to slow it down about %20 and added a 11"x8" cooler in the stock battery location with an air duct.
Due to the Champcar rules I'm a little limited to how crazy I can get.
Any other experience or ideas?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Power steering overheat 2X
Any kind of cooler will be a big improvement. Not sure if I would want to do the underdrive pulley though.
Axle/Gears: 3:23
In addition to cooling down the pump by slowing it down I was hoping to take away some of the twitchiness of the stock power steering. I definitely don't want a manual box but a little more effort would be nice. We're generally running 1 1/2 to 2 hour shifts in the car at 3500-5000 rpm so slowing down the water pump seems like an added benefit. I'm not tossing the stockers in the trash so its a 20 minute swap if that part doesn't work out.
Car: 87 IROC L98
Underdrive pulleys on a street car are even a bad idea. I had them on a pickup truck. Just slowing down the alternator caused low rpm problems.
On my race car, I have 3 belts. 1 for the alternator running at around 2.5:1. Vacuum pump is around 3:1 and fuel pump is around 1.5:1. Water pump is electric and manual steering. I spin the engine to around 7400 rpm but it's only there briefly.
All belt driven accessories are designed to run in a specific rpm range. Since you're staying below 5000 rpm engine speed, slowing stuff down isn't required.
If you were running circle track with the engine running constantly in the 6000-8000 range for extended periods of time, I'd consider slowing accessories down.
MaxxMitchell
Exterior Parts for Sale
Jan 15, 2010 07:34 AM
cobrakiller1989
Nov 4, 2000 10:10 AM
Black Beauty
Sep 25, 2000 10:40 PM
