Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
getting ready for race
Old Apr 3, 2002 | 12:27 PM
youngin's Avatar
Hey, I am pretty new to this board. I have been surfin it for quite some time and have decided to start posting a bit.
So here's my question. I am going to be taking my car to the track on friday. It is an 89 Trans Am GTA WS6. It has 350TPI, 4.10gears, shift kit, and a flowmaster 80 series muffler. What should I do to the car to get it ready for the races? ie. Timing, tire pressure, and anything else you can think of that might help. Thanks in andvance.
Old Apr 3, 2002 | 01:33 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
You can raise your timing some, just not too much or you'll get detonation. Let some air out of the rear tires.
Old Apr 5, 2002 | 09:04 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Maybe a tune-up. Plugs, wires, air filter, stuff like that.
BTW how do you like your 4.10 gears?
Old Apr 6, 2002 | 11:28 AM
youngin's Avatar
Reply to Tony89GTA:
Hey tony, I like the 4.10 gears alot. They are really nice for the "around town" power and I still can get up to about 180km/h maybe even more. I was just at the track yesturday and ran a 14.9 with just those basic mods on the car. I want get a little higher of a gear though, maybe a 3.9?. I am havin to shift into overdrive right near the top end of the track so I think I am losing a few tenths with that shift. Out of all the mods you did to your GTA which one do you think benefitted the car the most? How do your like your SLP cold air intake? I want to know real results from a car just like mine. Also what were the "free mods" you did and did you notice a difference after you did them. Thanks alot.
Old Apr 7, 2002 | 03:01 AM
Tony89GTA's Avatar
Car: 89 GTA
Originally posted by youngin
Reply to Tony89GTA:
I got to say the headers and the rest of the exhaust made the most difference along with the cold air but cutting two windows in the air intake can will give you about the same gain. My free mods were porting the plenum, gasket matching the runners, throttlebody coolent bypass, but I can't say if these did much.
Old Apr 10, 2002 | 05:38 PM
Phantomht's Avatar
Car: 84 Camaro Berlinetta
Engine: 377ci standard bore 383
Axle/Gears: 4.56
If your running street tires, do NOT lower the air pressure, only lower air pressure when running slicks. Street tires will use 30 - 35 psi as usual.
Do you have K&N filters? - Remove back seat[s], spare tire/jack, remember, every 100 lbs of dead weight costs you a tenth in the 1/4 mi.
Old Apr 11, 2002 | 03:03 AM
Administrator
Why would you not want to let air out of the rear tires on streets??
Old Apr 11, 2002 | 12:55 PM
85transamtpi's Avatar
If you drop the pressure lower than 25psi on a regular radial you can force the tire contact patch to cup...and you'll get less grip.
I say 25psi, but every tire is different.
Old Apr 11, 2002 | 03:49 PM
Phantomht's Avatar
Axle/Gears: 4.56
BEST thing to do is find some "unmarked" pavement, do a burnout, if there is more rubber [darker] on the outside of the burnout marks you just made, your tire is 'cupping' and you add more air, keep doing this til you get a nice even strip of rubber.
Old Apr 11, 2002 | 08:53 PM
Administrator
I'm not saying to let out like 10 PSI.
Old Apr 12, 2002 | 09:02 AM
I just noticed this...Be careful. 700r4's 3-4 clutch pack is NOT designed for WOT shifts. If you keep running with that gear, plan on rebuilding your trans often.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
