Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
MAF sensor on my GTA!
Old May 14, 2007 | 07:18 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
so my MAF burnoff relay went out, and it cooked my MAF. NAPA wants 170$ for one. if i am spending that kind of dough is there some better after market one i should be looking at instead?
thanks crewbies and other PNW folks.
Old May 14, 2007 | 08:40 PM
AmorgetRS's Avatar
Re: MAF sensor on my GTA!
You'd probably have a lot better luck in the Electronics or TPI section, however as far as I know the stock one is basically the best to go with. Most of the other GM ones (LS1, LT1) need convertors to work and don't really give any benefits.
Old May 14, 2007 | 08:59 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Try these guys
http://store.summitracing.com/partde...5&autoview=sku
We have one on our 95 camaro & love it.
Old May 14, 2007 | 09:30 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I have replaced several MAFs on various 3rdgens that I've owned and $170 isn't a bad price! I got lucky last time and found a working one at a junk yard. The bastard still charged me $60!
Old May 14, 2007 | 10:29 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I think that Napa sells the Wells type Tony (which I preferred). Either way if you can pick it up for $170 I would do it.
When I blew my last one up there wasn't enough of it left for a core so I was looking at around $300 to replace. The one that i purchased a few years before was only $145 with no core charge so they are going up.
Good luck.
-Schultzy
Old May 15, 2007 | 12:58 AM
Xophertony's Avatar
Axle/Gears: n/a
thansk for the input guys. i thought 170 was high, the v6 ones are WAY less.
777Shock777
Oct 29, 2015 04:30 PM
GTAman
Sep 21, 2015 09:57 AM
Logan Bryant
Aug 27, 2015 11:52 AM
soarestransam
Aug 24, 2015 08:15 AM
Bert87
Aug 23, 2015 03:50 PM
