350 crate motor 350hp/400tq boared .030 over
balanced and blueprinted
gm peformace rods
forged pistons around 9-10:1 compression
ported and polished heads
double chain timing chain
crane cam kit (springs,lifters,cam) good solid idle and power
steel crank
4 bolt main
full edelbrock crome kit. (valve covers,timing chain cover, air cleaner, alt brackets etc)
holley crome fuel pump
crome high flow water pump 30% more flow
high flow oil pump
edelbrock intake manifold
about 1500 miles on motor. runs and has awsome power.
900obo possible trade for bbc or sbc 400
1982-92 camaro full exhaust system 2.5 piping in to force muffler (same as flowmaster) sounded good not to loud -100obo
1982-92 camaro hedderman hedders have ypipe that goes with it. not to old only a few starts on them. 200obo
Msd 6al box with adjustable rev limit, i have all the chips for selectable rpm almost new! 150obo
can toss in a converted chevy hei for mag pick up.
auto gauge monster tach almost new. with shift light 50$
edelbrock high rise intake manifold peformer spread boar for sbc chevy 100$obo.
18/10 z06 wheels black with a crome lip wheels in good shape two tires are new and two have some camber whear but will last for a while. 600obo??
billet spacers for offset 2 are 2.5 and 2 are 2.25 will work for 82-92 camaro i have them mounted if u would like to take a look. would like 100 for spacers or sell as a package deal.
gm peformace rods
steel crank
4 bolt main
high flow oil pump
RJ_Moore
close
- Join DateSep 2009
- LocationVictoria, BC, Canada V8N1P5
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car85 SC and 87 IROC Both T-Tops
- Engine305 V8 H Code and TPI F Code
- Transmission700R AT/OD and 5 Spd.
- Axle/Gears7.625
- Liked:0 Times in 0 Posts
Where are you?
RJ_Moore
close
- Join DateSep 2009
- Axle/Gears7.625
How much for the car?
tri-cities... what car??? i am not selling my grey one. i just have alot of parts around
edelbrock 4bl carb square boar. almost new just did the regaskit kit from edelbrock.
i also am tossing in a edelbrock trick kit with all the stuff you need to jet and tune the carb for your set up.
150obo need it gone! make me a offer
edelbrock peformer intake spread boar for sbc chevy-offer
what size are the headers that you have?
i need some that dont have any AIR tubes on them.
they might be sold idk yet - 85 5.7 irock-z
they have no air turbes non emmissions
iam not sure on the tubes them self but i know the bottom is 2.5 or 3inc
i gotta get the emissions headers off my TA then i can pick these up from you.
got the motor out if ur still intrested in the headders.
motor still for sell?
motor is gone. sorry it took so long
