Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Won't start?
Old Aug 13, 2001 | 02:40 PM
84-Z28Cruising's Avatar
Won't start?
I have a 84 Z28 Camaro that won't start. Yes, I have checked the battery and it is fully charged. What is the next step to figure out why it won't turn over? Be easy on me, I am new to this website. I know enough about cars to get into trouble, so don't make it to technical. Thanks Also, the drivers side seat belt won't retrack into the head liner slot. I understand there was a recall on this. If this is so, is it a open recall? Thanks.
Old Aug 13, 2001 | 03:14 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
could be any of the following:
Alternator, Coil, Cap, Rotor, Module, Starter, Starter Wires (stupid damned wires, I hate them)...
Sometimes it'll just turn over and not fire with those though... so... if it doesn't even turn over, look at Alternator, Starter and Starter Wires...
Those are so fun to play with
Old Aug 13, 2001 | 03:28 PM
DeathZ's Avatar
I'm guessing that you have a carb and not TPI.If you take your air cleaner off , and pour a little bit of gas directly into the carb and if it runs then your fuel pump is shot.Another thing make sure that your getting spark to the spark plugs and check the power wire on the distruber....this happened to me the other day....I was stranded for hours and the only thing was wrong was that the power wire slipped off the distruber cap. Still makes me mad. Hopefully that will help.
Old Aug 13, 2001 | 07:49 PM
I'll take a look at the wires going from the battery to the starter. The starter doesn't make a sound and neither does the solenoid. So maybe there is something wrong with
both. Who knows, thanks for the input.
<font face="Verdana, Arial" size="2">Originally posted by Demon Z28:
</font>
[This message has been edited by 84-Z28Cruising (edited August 13, 2001).]
Old Aug 13, 2001 | 08:19 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 84-Z28Cruising:
What is the next step to figure out why it won't turn over? </font>
That narrows it down. Try shorting out the trigger wire to the starter. Take a 3 or 4 foot lengh of wire and strip one end about 1-1/2". Wrap that end around the small terminal on the back of the starter solinoid(sp?). Take the other end and strip 1/4" inch off the end. Now touch that end to the positive terminal on the battery. Did it turn over?
If no, replace your starter.
If yes, you have a wiring issue with your starting circut.
Old Aug 13, 2001 | 09:01 PM
85ROCZLADY1's Avatar
Welcome to The Cascade Crew!! We help each other out here, so you have nothing to worry about here!
BTW, '85 was the first year for tpi.
[This message has been edited by 85ROCZLADY1 (edited August 13, 2001).]
Old Aug 13, 2001 | 11:16 PM
84FBODY's Avatar
First thing I'd do is replace the starter. If you turn the ignition to start and it won't crank over then the solenoid is shot. Since you can't replace the solenoid just buy a new starter. 40 bucks at Napa.
John Chamberlain
1984 Sport Coupe Camaro, 1979 350. Dynomax 2 3/4" cat back single in dual out muffler. Have Heads, Weiand Stealth intake. Sonn swapping in a manual and redoing the interior! (Soon as in now )
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
