Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Pulling 305, advice on what to do with it?
Old Feb 22, 2023 | 10:16 AM
1991whiteRS's Avatar
New to posting, as I'm now down the rabbit hole of an engine swap. I searched around and didn't see this topic.
390/420 crate 350 is on order. Pulling the 1991 RS 305 with 85k original miles. Zero leaks, ticks, smoke, etc.
My question - any idea what to do with the stock motor? What's a stock 305 worth? How best to manage the sale and timing of the sale if I found a buyer, etc? I could save it, but i imagine it would just be in the way for the next ten years. Car is scheduled for suspension and engine swap in about 6 weeks.
Old Feb 22, 2023 | 11:23 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Pulling 305, advice on what to do with it?
It has zero value on the open market. However, being at only 85k miles you may donate it to someone who needs a replacement. Other than that, you'll be giving it away to someone sooner or later. Make a cool end table out of it.
Old Feb 22, 2023 | 11:46 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Wish you were closer, I'd take it but the shipping alone wouldn't make it worthwhile.
Old Feb 22, 2023 | 11:56 AM
Thank you, kind of what i figured...
Old Feb 22, 2023 | 12:41 PM
Bishopts's Avatar
Car: 1988 gta
Engine: 5.7
Axle/Gears: 3.27 posi with discs
500 shot and push it till you have to tow it home. Make sure you have a gopro
Old Feb 22, 2023 | 01:26 PM
Bishopts's Avatar
Car: 1988 gta
Engine: 5.7
305 is no chump
Old Feb 22, 2023 | 01:45 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Sounds like you need to install some leaks, a tick, and 2 smokes so you can go ahead and get that outta there.
Old Feb 22, 2023 | 02:55 PM
JDW88's Avatar
Curious what part on PNW? Looking to get my 88 running again and have been trying to find a 305 to get it going.
Old Feb 22, 2023 | 08:48 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I'd keep the engine until the swap is done just in case you need to pilfer good parts from it. If your car is clean it is NOT EASY to find parts like that again. Then put a price on it and see what happens.
Old Feb 22, 2023 | 11:01 PM
Not bad advice, i have a growing pile of OEM gear that I'm hanging on too.
Old Feb 23, 2023 | 08:23 AM
Bishopts's Avatar
Car: 1988 gta
Engine: 5.7
Is it a tpi car?
Old Feb 23, 2023 | 08:30 AM
lake tapps area…
Old Feb 23, 2023 | 08:56 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
I'm assuming this is the original engine from the car.
After you pull it, remove the spark plugs, shoot some oil into the cylinders, replace the plugs, then store it indoors. At some point down the road, you may decide to sell it or give it away; just don't do anything hasty right now.
Old Feb 23, 2023 | 09:02 AM
Thank you, good advice, i have the original wheels, mint condition as well, I'm certain if i sold them i'd regret it down the road
Old Feb 23, 2023 | 11:19 AM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
I cleaned mine up and its on an engine stand in my garage looking cool.
Old Feb 24, 2023 | 07:22 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Mine had 91k mi with just a lil smoke on startup. Sold it for $400 or $500. Went in a TBI pickup worked well for both of us. 305s are a decent lil engine. They are worth something.
Old Feb 24, 2023 | 08:40 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
That's what I did with mine. Nice donation to a local guy. He picked it up and it was out of my way.
Old Feb 25, 2023 | 08:55 AM
Dont believe so...
Old Aug 19, 2023 | 01:43 AM
cagedruss's Avatar
Car: 84 Camaro Z28
Engine: 5.3
Transmission: Tremic 6 Speed
Axle/Gears: 3:43 posi
where are you located? I might be able to help.
Mr.cannonrider
Dec 15, 2023 09:52 PM
ohiosteve
18
Feb 15, 2012 10:41 AM
Paul_Hughes_87 T/A
17
May 21, 2002 01:36 AM
019890Fbird0
Apr 4, 2002 07:35 PM
chevy5711
May 8, 2001 06:17 PM
