Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Thirdgens Suck ;)
Old Feb 9, 2002 | 12:42 AM
Blue502's Avatar
Thirdgens Suck ;)
Went out and ran the code on my IROC today. Code 54 - low voltage to the fuel pump. Doesn't make sense though since if anything it is pumping too much fuel, and low voltage would cause too little. Towed it up to my mechanic. Let him figure it out...
I'm afraid that it is probably a faulty ECM though. When I first got the car and we were getting it running it was throwing all kinds of weird ECM codes, and all of a sudden they stopped. This is the first code the car has thrown since then.
Old Feb 9, 2002 | 01:27 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
that sucks, hopefully the mech, will fix it soon, and not cost too many bones.
Old Feb 9, 2002 | 05:50 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
RE: thirdgens suck
maybe you should go and buy a RX-7
Old Feb 9, 2002 | 10:17 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
When fuel pressure is low the injectors just pour through instead of spraying. Then itll flood even though you'd think the opposite would happen. Hope it doesnt take too long to fix.
pimp2303
Jul 27, 2017 02:03 PM
355tpipickup
Aug 27, 2015 08:13 AM
TheExaminer
Aug 26, 2015 04:59 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
BurlyChev
Aug 16, 2015 09:08 PM
