Parts Wanted 2006 Looking for something in particular? Ask here.
Need VSS / reverse light wiring for t-56 swap I did!!
Old Mar 31, 2005 | 10:42 AM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
I'm having so much trouble finding these specific harnesses or even information on them. Can anyone help me out? Thanks.
Matt
Old Mar 31, 2005 | 07:56 PM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
Go to any junkyard and grab a 2 prong male style connector that looks like the one that will fit into your reverse light female connector on the trans. Make sure and cut the wires 6 inches or so (that way you have something to connect your new wiring to). Go to the store and buy about 10 feet of 12 gauge wire. Go home and look at the original wiring on the neutral safety switch. If your car was an auto the purple and yellow wires will need to be either wired to the clutch switch or just wired directly to each other. If you wire thhem to each other your car will be able to start while it's in gear-not a good idea- Anyhow there will be 4 more wires at the neutral switch. two are solid colors and 2 have a black stripe. Wire the 2 solid colored ones (not yellow or purple) to the switch you bought at the junkyard using the wire you bought at the store. It does not matter which wire goes to which. Plug it in and whalla! Homemade wiring harness. This is how I did mine and it works great.
camaro11j
Sep 19, 2018 08:49 AM
mizz0313
Aug 12, 2015 06:45 AM
Omega
Aug 10, 2015 12:46 PM
hokis
Aug 9, 2015 03:57 PM
cRoe4
Aug 7, 2015 08:46 PM
