AC/smog delete pullys
smog delete pulley
The smog pump delete pulley is still available from GM part #10186167. I just bought one and it only cost around $40.00, for that little money it is worth just buying new in my opinion and you know what you are getting.
As far as the a/c delete pulley I don't know, I was never interested in getting rid of the a/c so I never investigated that, although I am sure someone here can chime in on that, I believe that GM also sells one that I have heard people refer to as a 1LE a/c delete pulley. I am sure someone here knows, hope this helps, Larry.
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
ya...i think i might end up buying them new...they don't seem to common as a used product...i just did an e-bay search and this one guy wants over 60 buck for a ac detee pully, when i can get one new for less....i can't figure out how people can ask so much money for something that is cheaper to buy new....
exactly
Thats funny, I was just discussing fog lights with another member that fall into the same situation. Used ones on ebay are fetching good money and they are still available new from GM, and when buying new atleast you know what you are getting.
I agree, the pulleys are cheap enough from GM it is hardly worth searching for used ones. I just was not sure if you were aware that they are still available from GM so I thought I would throw that out there just in case, later, Larry.
Car: 91 RS Camaro
Engine: 305 TBI
Cruisin,
Why don't you just re-route your belt to run without the AC or Smog pump? All you have to do is buy a 66" belt and route the belt completely around the tensioner pulley instead of going down to the airpump and the ac. My car has been set up that way for probably 2 yrs. now and it runs fine. Save yourself some money and time too. You can also leave your stuff hooked up if you want and just put on another belt if you want to run them again. Great for winter time horsepower.
Car: 90 ws6 formula
Engine: 305 tpi
Transmission: t-5
I just ordered my delete pulleys from gm, the part # above is correct and the a/c delete part # is 10115875. hope this helps
Not sure about the part number any more just checked the gmpartsdirect.com and it said for 93 up. ill let you know when they come in.
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
The A/C delete part number you ordered isn't going to work for you. Thats the LT1 A/C delete pulley.
It was posted on 1le.net for third gens.I need to let them know.
