Vacuume Advance Hei
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Vacuume Advance Hei
Wanted HEI for NON-ccc car in verey good condition with HP coil or without. Please ouote with shipping to 10801 .
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
It worked fine when removed I would put a new rotor on it. I do not know if your cap and coil will work. This is a stock HEI for a in cap coil. No cap or coil included with it. The only reason I took it out is I got a free used MSD from a friend.
Car: 85 IROC Ht
Engine: 383 carb
I have the cap coil and rotor from my ccc-carb it works on the old HEI correct . If so let me know how you want the loot and when you can send it out . PM me if we are all good .
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
CCC carb will not work with old non-ccc HEI
it will run rich default and flood out plugs and make smoke out exhaust, been there doen this a million times
i have a good CCC Q jet off my 88 with 305 and 700r4 it runs good if anyoen wants it 35 and mail., i converted to non CC carb and HEI
i also have air injection reaction smog pump parts for sale and all that stuff, 88 carb half serpentine style
we dont have inspections or testing in IL
thanks
thanks
Car: 85 IROC Ht
Engine: 383 carb
I had it the other way around non cc-carb with the ccc-distributor . Thank's to NoIsNotForSale I have the correct distributor .
86CamaroDan
Sep 29, 2015 10:08 PM
