complete 350 TPI
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
complete 350 TPI
im looking for a complete 350TPI with harness and computer. possibly engine and manual trans combo. willing to drive for pickup. Im in chicago IL. anyone near?
im not near but i have a low 13 sec. combo for sale. Although its an auto trans. but ill sell the motor, and the entire TPI system, harness, and all the sensors to you for 3500 OBO. Lemme know heres the specs on the motor
355
ZZ4 cam
World products S/R tourquer heads 2.02/1.60 valves
TRW hyperetechtic pistons .125 dome
GM powder rods
GM crank, ground .010/.010
Ballanced
ARP rod bolts
ZZ4 springs
High pressure/volume pump
Summit racing 1.5 roller tip rockers
355
ZZ4 cam
GM powder rods
Ballanced
ARP rod bolts
ZZ4 springs
I have a 1985 TPI set up. Came off a 305. Same as a 350 TPI except for injectors. If you were gonna hop up a 350, you wouldn't even use stock 350 injectors. If you are gonna need a TPI for perimiter bolt heads, this will work. I have everything but a distributor including complete air cleaner. Yours for $350. Will be in Milwaukee the weekend of the 22nd if you wanted to pick it up.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
350 with tpi. needs to be rebuilt. I have a crank and rod for it. (spun a bearing) hour 1/2 to 2 hours from chicago
Sanjay
Aug 12, 2015 03:41 PM
