Parts Wanted 2006 Looking for something in particular? Ask here.
Tpi
Old Oct 8, 2005 | 02:03 PM
blander66's Avatar
Tpi
I am in need of a TPI setup. I do not need a computer or harness. I need it for a non center bolt head setup.
Old Oct 8, 2005 | 02:59 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
I have one it is pre 87 make an offer it yours the thottle body ione it was junk so its not there and the previous owner stripped out the bolts and painted the thottle body shut which I broke trying to get it to open
Old Oct 8, 2005 | 03:17 PM
blander66's Avatar
does it have the distributor, fuel injectors and any sensors?
Old Oct 8, 2005 | 03:35 PM
ND4SPD86's Avatar
A couple of the injectors are bad the previous owner kept the distributor and threw a way the sensors so just make an offer on it
Old Oct 8, 2005 | 04:34 PM
blander66's Avatar
Could you send me some pictures of it to wr-bland@wiu.edu
Old Oct 8, 2005 | 04:38 PM
ND4SPD86's Avatar
I do have pics but I need to get the film developed
Old Oct 9, 2005 | 10:46 AM
Tiresmokin's Avatar
1985 TPI
I have a TPI set up off an 85 Z28. I'll have to check, I don't think I have the distributor, but should have the rest. $400 plus shipping
Old Oct 9, 2005 | 01:43 PM
blander66's Avatar
what all does that setup include?
Old Oct 9, 2005 | 03:36 PM
Tiresmokin's Avatar
It includes:
Runners(some dings)
Plenum
Manifold
Throttle body
Fuel rails/injectors
Thermostat housing
Egr valve
Mass Airflow sensor
Rubber boot for sensor
Spark controller?
ECM
Wire harness(has 6 or so wires in a clump that ends were cut off)
Air cleaner top and bottom
$65 for shipping, another $20 for air cleaner if you want that. Has to go in seperate box. I don't think I have all the factory bolts. It was purchased as a back-up unit and was suppose to be in good working order. I don't know for sure cause I never used it.
Old Oct 9, 2005 | 03:38 PM
Tiresmokin's Avatar
If you don't need the wire harness or ECM, $350. Does have 9th injector.
Old Oct 9, 2005 | 03:57 PM
blander66's Avatar
What would the price be with out the MAF sensor, ECM, Harness, Air ducting and Spark controal be?
Old Oct 9, 2005 | 06:17 PM
Tiresmokin's Avatar
If you mean rubber boot and air cleaner when you say air ducting, The lowest I will go is $325 without the items you mentioned. I sold a complete unit on Ebay for $510. I figured this set up must be worth at least $400 on there. Shipping would probably be about $60 without the other stuff. I don't know where Crystal Lake is, but I will be in Milwaukee for the Snow Show on the 22nd or 23rd if you'd want to pick it up?
Thanks,
Scott
Old Oct 9, 2005 | 06:51 PM
blander66's Avatar
let me think about it because there are setups going for around 200-250 on ebay right now
Old Oct 9, 2005 | 07:26 PM
zerokill78's Avatar
Car: 93 z28,89 formula350 92 formula350, 92trans am 350 6-speed,1992 3.1 firechicken,1991 z-28 350..1986 hearse
Engine: several350tpi,lt1,3.1(haha)
Transmission: auto...6-speed
I have an intake...fuelrail...plenum..and runners off a 1986 Iroc...no maf...gooseneck..or distributor....$250
Old Oct 10, 2005 | 12:00 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
i have everything need to start the car minus the sensors that are connect to the block and it is a painless wiring harness, heres a link for an ad i have on here, i am looking for around $500 obo, but let me know
TPI ad
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
