Serp Bracket Needed
Car: 93 z28,89 formula350 92 formula350, 92trans am 350 6-speed,1992 3.1 firechicken,1991 z-28 350..1986 hearse
Engine: several350tpi,lt1,3.1(haha)
Transmission: auto...6-speed
I tryed to remove the P.S. pump from the bracket and can not get the pully off sorry
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
Not sure if this helps any, but I *think* this is the bracket you are looking for. Only pic I could find of it while here at work was one with the p/s pump and alternator on it, but it's highlighted there in red.
It can be found at Scoggin Dicky http://www.sdpc2000.com/
under part number 10105212 with a price tag of $60.78 before shipping.
Direct link to item: http://www.sdpc2000.com/search.asp?s...5212&doquery=1
Pic below:
Pic below:
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
thanks for the legwork big...that is the exact bracket i need. i cant believe its so much though. if i cant find a used one for a good price im debating on getting mid mount brackets for the alt and ps pump but they are $100 a piece
man i cant believe i broke mine!
Car: 1992 RS
I ran the part number through gmpartsdirect.com and found it listed at $41.35 +shipping. If I recall correctly that is how I went about putting my serpentine system together rather than buying the kit. The drawback to gmpartsdirect.com, atleast in my dealings with them, is shipping seems to be slow. Though everything has arrived as described and has worked exactly as intended. Don't know why I didn't remember that while I was at work, just thought about it on the drive home.
Car: 1991 Z28
Engine: 383
even better! after you brought up the first post i went searching through my bookmarks but didnt make it to gm parts direct yet. i still want the other kind of brackets though. i think the mid mount brackets look 100x better than the ugly serp bracket...shell out $200 or $50?
Car: 1992 RS
Now that makes me wish I would have had my camera at car show a few weeks back. I saw a 55' 2 door hard top with the same serp set on the front. Only it had been powder coated to match the color of the car. Looked awesome. I've also seen quite a few that have just taken some elbow grease and polished up the aluminum and they've turned out really nice too. If you've got a few hours, some buffing compound and buffing wheel, try it out.
Car: 1991 Z28
Engine: 383
well i am going to paint it alumnium with the engine paint i used for my waterpump but i just dont like the way it makes the alt stick above the valve cover and it gives the engine an unbalanced look
Car: 87' Pont GTA
Engine: 5.7L
I have some! They are Cleaned, Inspected and Ready for Installation. The price runs $40.00 plus shipping and handling.
Thank you,
Thomas
(800) 460-6789
www.houseofcamaro.com
Thank you,
Thomas
(800) 460-6789
1992 Trans Am
May 10, 2023 07:19 PM
