Parts Wanted 2006 Looking for something in particular? Ask here.
WTB: firebird headlight module/relay
Old Nov 17, 2005 | 10:25 AM
llvll4l2c91350's Avatar
looking for a headlight relay/module for my 91 formula in good working condition. my current one works only sometimes and when the lights dont go up i have to tap it with my hand to make 'em go up. its very annoying. thanks.
Old Nov 18, 2005 | 12:49 AM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Axle/Gears: 4th gen 3.42 posi
I'm parting out a '89, will they be the same? Can you send me a pic or tell me where it is. I'm a Camaro guy. I'll be selling or trading Firebird specific parts.
Old Nov 18, 2005 | 07:10 AM
yea they are the same. u sure it works perfect? on the car its located on the firewall on the drivers side. its gonna be a black box looking thing with the word GUIDE on it. gonna have 2 plugs to it.
Old Nov 18, 2005 | 05:49 PM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
I've been wondering what that was since Camaro's don't have them. As it turns out I'm working on a '91 Firebird. I'll test it out and let you know.
Old Nov 18, 2005 | 06:11 PM
thanks
Old Nov 20, 2005 | 02:55 AM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Sorry man, it would only lift the passenger side and wouldn't close it. It's junk. Good luck with the search.
Old Nov 20, 2005 | 11:53 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I have the Headlight Control Module you're looking for available on my web site.
Lon Salgren
Top-Down Solutions
Old Nov 20, 2005 | 07:40 PM
Tiresmokin's Avatar
Headlight relay
I have one in my 87 GTA. The headlight motor gears are stripped. If I turn the headlight switch on- they run. If I turn the headlight switch off- they run. I guess it is good right? Don't know if it fits a 91. Interested?
Old Nov 20, 2005 | 08:18 PM
lonsal's Avatar
It is the same module 1987-92. However to test it properly the bushings in the gears must be good. That way you'll know that the module is turning the motors off when it senses the current spike from the motors hitting the stops and not just turning them off by timing out. I've had modules that were bad only because they wouldn't turn the motors off from the current spike. You'd hear the motors continue to make noise after they hit their stops until the module timed out (roughly 5-7 seconds). Nothing hurt by trying the module out, you just wouldn't want to continue to use it long-tern if it does turn out to be bad since it would wear out the bushings or gears quicker.
Lon
Old Nov 21, 2005 | 10:28 AM
thanks lon. i went ahead and ordered it thru ur site.
Old Nov 28, 2005 | 05:58 PM
got the module lon. sent u a PM.
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
TA8487
Aug 16, 2015 12:21 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
