New belt set up
Old Sep 10, 2003 | 05:40 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
New belt set up
Well I redid the twin blower setup to use its own belt vs the long single I had originally used. Shredding a $35 belt with regularity was getting old.
Moved both blowers forward, shortened the pipes to the intercoolers, and relocated and added a second bov.
Fabbed up a dual crank pulley by welding a Ford SC blower crank pulley to the existing TPI serpentine pulley.
Blowers now have a 78" 8 rib belt all to there own, and the alt,WP,PS have a 77.5" 6 rib for them.
Adding the second bov has made the blowers much quieter. The single apparently did not pass enough volume causing boosted air to back flush the blowers.. You can now hear the injectors ticking at idle.
Now to clean the thing up and take her for a test drive.
BW
Old Sep 10, 2003 | 05:41 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
closer look.
Old Sep 11, 2003 | 11:34 AM
90formula5spd's Avatar
Car: 1989 trans am
Engine: 357sbc
jesus christ, i have the most repsect for u!, wow i dont think i ever woulda thought of that but ur obviously better educated than me so far, i dont kno as much as u do, well done! well done!
Old Sep 11, 2003 | 09:17 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Maybe he should give you spelling lessons. J/K
Looks great Saturn. Can't wait to hear how the test drive goes.
Old Sep 11, 2003 | 11:13 PM
DreamState21x's Avatar
How the F*** does that work? I've never seen anything like that before.. where did your heads go.? and if they are under there how is the TPI sitting so high.. Great job man..
Old Sep 11, 2003 | 11:25 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
Just when you have us thinking "thats as cool as it gets" theres something else.
nice work!
slick
Old Sep 12, 2003 | 04:55 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Re: **
Blowers are mounted just above the valve covers. Unbolt the blowers and plates and its just a plain ol tune port motor.
thanks, BW
Old Sep 12, 2003 | 04:56 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
nice work!
slick
Its just a toy..
thanks, BW
Old Sep 12, 2003 | 04:59 PM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
Silly question man. Are your et times you posted before or after you built your twin charger set up?
Old Sep 12, 2003 | 05:01 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Test drive went well... spun the engine to 6K in first, hit second, and lifted.. and the belt stayed in place. It would have tossed it before.. About the only problem was the dipstick wasn't seated and oil blew out the tube.. nasty splatter all over.
Waiting for the second bov to arrive.. that will help too.
Boost is down to 8 lb, which I figured since the new crank pulley is 1/4" smaller diameter. Need to scrounge up some 10% overdrive pulleys for the blowers.
cheers, BW
Old Sep 14, 2003 | 11:03 AM
D M N's Avatar
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
has anyone ever tried to replicate your setup? i mean thats a awsome cheap and functional setup
Old Sep 14, 2003 | 04:54 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
I've hit the track twice, with the 14.4 run the best so far of 3 runs made. Between belt problems, and lack of traction (no dots or slicks) thats as good as its been. The 305 I'm currently running is a POS I am using to build/test/debug the blowers. Now that I beleive the bugs are sorted a new motor is being built. Also will upgrade the rear for slicks this winter.
It's been a fun summer playing with this puppy. BW
Old Sep 14, 2003 | 05:01 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
As far as a chevy goes, I am not aware of any other than rooster433's single M112 blown LT1.
I know of a couple Fords.
83 Crossfire TA's brother's 5.0L single M90 LDTII and Mike Sitar's twin eaton Thunderbird.
Mike's site, www.toohighpsi.com is what made me try a chevy version.
Cheap and functional, possibly, however it's still a one off type project.
BW
Old Sep 14, 2003 | 05:06 PM
Engine: 350 L98
Wow that a 305. Ok that makes sense. Plus all the trouble you've been having with bugs and all. Whats the new build up look like? Are you sticking with TPI? What are your expected HP numbers?
Good luck dude. The look of your setup alone would scare most people. Never mind how fast your going to go.
Old Sep 14, 2003 | 05:19 PM
D M N's Avatar
Engine: 3.4 DOHC
Do you know the guy that did that setup on the T-bird and is he on this forum??
Old Sep 14, 2003 | 06:13 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Personally, no. I have never spoken to Mike, and I have never seen him post here. He's a big Ford racer, probably find him on one of the blue oval boards.
BW
Old Sep 14, 2003 | 10:47 PM
wait
So your saying that twin blower set up only ran a 14.4?
Old Sep 15, 2003 | 01:36 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yes, that is what he said, and he also said that he had a massive amount of wheels spin. he said that he spun to 6k in first and the hit second and lifted.
Old Sep 15, 2003 | 06:50 PM
ic
I missed that part.. Makes more since now.. Now those are some traction issues..lol
Old Sep 15, 2003 | 08:46 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
I think your confusing two different times.
At the strip, both wheel spin, and belt tossing at the top end have limited my strip time, and et's.
The 6K shift to second lift, is after I redid the belts to two, and was trying to get it to chuck the belt. So far.. so good.
thanks, Bob
Old Sep 15, 2003 | 09:37 PM
mw66nova's Avatar
Engine: 7.0L
oh, sorry bout that, either way, the car was not in top performing operation to get a decent et...correct?
Old Sep 15, 2003 | 10:06 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Nope..
BW
Old Sep 16, 2003 | 01:24 AM
83 Crossfire TA's Avatar
Mike sold the twin eaton setup off the t-bird and has converted the car to be a single turbo car to run in the drag radial classes. Last I talked with him he was hinting at doing something similar to a C4 vette that he picked up last year.
Yes I do and no he doesn’t.
Old Sep 16, 2003 | 03:26 PM
D M N's Avatar
Engine: 3.4 DOHC
What is that thing he built with the turbo i mean is it just a intake manifold or is it a intercooler too and where is the TB
Old Sep 16, 2003 | 04:57 PM
It’s an air to water intercooler mounted as part of the upper manifold. The lower started as a stock 351 truck manifold that he’s milled. The upper also has bosses for 8 extra injectors. Mike has a friend that makes intercoolers and made this one and the one on crazy joe’s car (there are links to his stuff on the site and you can see a pic of him working on the one in crazy joe’s car on the site).
Old Sep 17, 2003 | 10:20 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I saw that car at Sears once, and then at Quaker Steak later, it makes a sick sound
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 22, 2015 07:13 PM
mustangdmurder
Aug 21, 2015 07:17 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
