HSW Nitrous Install Completed
Old Jun 27, 2010 | 11:31 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Finally got all my **** together. Bottles empty right now.
HSW makes good stuff at great prices. Plenty of people running 300+worth of n2o on their products. This is just a universal wet kit that i changed to my needs.
Starting in the back...I made a custom seat delete box to mount the bottles too out of 5/8 mdf and covered it with matching dove gray carpet. I'm using a filter, and a blow down tube. For those of you wondering what that skinnier bottle is for, it's filled with nitrogen to keep the nitrous pressure constant. Don't have to run a heater that way. You can also see the Mallory 685 ignition i'm running. Has a 2 step, single stage retard, start retard, boost reference if needed, and other ****. It pulls timing when the noids are activated.
Ran the ignition box wires through the center counsel, and the nitrous line through the door jam than into a 3/4" hole in the firewall. The blow down exits right by the factory hole plug. You can see how I'm getting fuel, and how i mounted everything.
Couldn't find a decent spot in the factory intake to mount the nozzle, so i used some silicone and pipe to get it done.
Mounted the microEdge in a pretty visible spot. It controls everything and all the settings can be customized. Flick the arm switch, purge, and drive! it does all the thinking for you. The switches are in the ash tray btw....pretty clean.
Overall it wasn't hard at all to install, just make sure to record all your wiring and keep everything straight.
Old Jun 27, 2010 | 11:38 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: HSW Nitrous Install Completed
Very clean install, nice job!
Car looks great to
Old Jun 28, 2010 | 02:03 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
very very nice install, looks similar to mine under the hood, i actually put mine in the maf after the sensor wire
Old Jun 28, 2010 | 03:29 AM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Nos is addictive! heres my setup...
Old Jun 28, 2010 | 03:32 AM
On Probation
just noticed, it looks like you used teflon tape....
i advise to take the system back apart, and get rid of the tape...get some teflon TFE paste instead...
the tape WILL wreack havoc on your solenoids, and has the capability to lock a solenoid OPEN. use paste !
Old Jun 28, 2010 | 03:34 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
personally i've never had any luck with teflon paste, don't know if it was just old or what, but the guys at Nitrous Outlet gave me a little tip to use red loctite instead, works great for me
Old Jun 28, 2010 | 03:41 AM
On Probation
were you using TFE paste? there are different versions of the teflon paste..
and yeah, Dave and the guys over at N20 outlet are good guys, ive been a customer there for YEARS! honestly hadnt heard of the loctite idea, but if dave said it, id beleive in it!
Old Jun 28, 2010 | 09:54 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Nice setup 89fbird!
lol i knew someone would point out the tape. I started it 3 threads in from the end, so it should be just fine. The only reason i used the tape was because i couldn't get the angled an-npt fittings where i needed them with red locktite, with the tape i could get them right where i needed them. I actually stripped the 45* fuel fitting trying to get it pointed up and left good thing i had a few extras. IDK i might go back and use the gel on all the straight fittings.
Old Jun 28, 2010 | 03:38 PM
Ronny's Avatar
When I put together my Aeromotive VAFPR my racing buddy said I should not have used teflon paste. So I disassembled and used tef tape. Now I installled my NOS name brand system and they state use paste. So on assembly I pulled the tape and used all paste. I can see how a sliver of tape can wreak havoc on the fuel side and you run lean as a result. So I am back to paste. Also at big box store I found something that resembled tef paste but was non drying sealant and gray in color. It is not teflon paste. I notice when tef paste dries it seems to give off dry particles. comments?
Old Jun 28, 2010 | 03:44 PM
On Probation
yes..its TFE paste, should dry as white.
the grey stuff is for plumbing applications in household stuff i think..
i could care less if the fuel solenoid gets stuck open...its always the nitrous solenoid i worry about....
having a N20 noid continuing to spray is BADDDDDD news.
Old Jun 28, 2010 | 03:45 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Probably was Rectorseal Sealant. They have a paste for just about everything. I like the No. 7 the best. Their website lists what materials each paste is compatible with.
Paste or not, an installer needs to be careful about contamination.
http://www.rectorseal.com/chrt.htm
EDIT: The 3M brand white stuff I have has TFE in it and works well.
Old Jun 28, 2010 | 04:12 PM
Ronny's Avatar
Well gasoline and aluminum are the two I need to check into.
Old Jun 28, 2010 | 04:23 PM
Ronny's Avatar
I was refering to fuel solenoid stuck closed. NOS brand solenoids are normally closed. the solenoid pulls open. So I presume catastrophe can result from fuel stuck closed or N20 noid stuck open.
Old Jun 28, 2010 | 10:22 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Damnit idk what to do now...
Old Jun 28, 2010 | 10:34 PM
On Probation
just use TFE paste or red loctite...and you will be fine..
just make sure to get all the teflon tape out of the threads of the noids, and off the fittings.
Old Jun 28, 2010 | 10:40 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
I got red loctite gel. Guess i'll be taking it apart and hope i can get **** to line up lol
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
toronto formula
Nov 10, 2015 06:17 AM
KO1
Aug 31, 2015 06:31 PM
