smog pump supercharger
Old Jan 25, 2011 | 09:17 PM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
has anyone else found an article online talking about turning 3 or 4 smog pumps into a supercharger? i read one last night that said by hooking up 3-4 smog pumps in a series that it would produce around 4-6lbs of boost. the author of the article said he had done this on a few cars but mainly on bikes. Just wondering what everyone on here would have to say about it?
Old Jan 25, 2011 | 10:06 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: smog pump supercharger
do you have a link to the article?
Old Jan 25, 2011 | 10:37 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
probably would work decent on a 3hp briggs&stratton,
but nowhere near enough volume to use on any 3rd
gen engine-i don't think you could fit enough smog
pumps under the hood,no to mention the drive problems
Some vane type superchargers were used back in
the flathead ford era,but i havent seen any modern
vane type superchargers(not to be confuzed with
centrifugal superchargers)
Old Jan 25, 2011 | 10:47 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
that's some funny stuff there. I bet if you grabbed 4 trans pumps you could make more psi
Old Jan 25, 2011 | 11:22 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
im calling complete b.s. on that one. it'd look to rediculous too.
Old Jan 26, 2011 | 08:35 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
http://www.turborick.com/dirt.html here is a link. It would look ridiculous with a ton of junk under the hood. just thought id see what everyone else thought of this.
Old Jan 26, 2011 | 11:25 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Id have to try it to believe it. i dont have a project car to try it on. and even at that 4-6 of them for a smaller v8 is just not feasible IMO
Old Jan 27, 2011 | 04:00 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
I,ve got some smog pumps for sale, you wanna buy 'em? LMFAO, what next?? Maybe AC compressors, hairdryers, I have some of those too....
Old Jan 27, 2011 | 07:37 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
only valid use heard of, is a scavange/vacuum pump plumbed backwards to pull gasses out of an engine, caue an electric pump to do that for you is $$$$$ racer stuff.
Old Sep 12, 2012 | 06:40 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Ok this sounds interesting. Just reverse the hoses or what?
Old Sep 12, 2012 | 08:29 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
some ford trucks had the inlet on the top just hook the hose to valve cover. need a good separator, oil in the smog pump leads to a quick death. vanes are made from composite material
Old Sep 12, 2012 | 09:16 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I got a .10 by using 4 of them
Old Sep 13, 2012 | 12:51 PM
Ronny's Avatar
How is availablility cost of multiple turbochargers gotten from a bone yard. Like from smaller domestic or foreign cars?
Old Sep 20, 2012 | 02:38 PM
prossi's Avatar
Smog pumps.. WTF....you can also run a hose from the interior to your intake and get someone to blow into it as you accelerate...should be good for about 2PSI, until they pass out
italiano67
Dec 11, 2016 09:21 AM
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
