another question on cams
Old Apr 16, 2002 | 05:20 AM
simple's Avatar
ive read post upon post about "blower cams" but i just cant find anything for my setup. i know i should call comp cams or elsewhere and talk to them but i live in hawaii and for some dumb reason, calling long distance is a b****. so anyway, i wanted to get some input from you guys as to what cam would be ideal for my application. heres the breakdown of my car:
89 T/A (L98), fully balanced 355ci 9:1CR
vortech s-trim @6psi, 24# injectors w/FMU
stock heads - decked/3 angle valve job
exhaust is all stock cept for gutted cats
rebuilt 700R4 w/vette servos and shift kit
3.27's in the rear
custom prom (as soon as i pick my cam)
despite all of the searching/reading ive done, im still a newbie when it comes to cam selection. so what do you guys recommend? my desired RPM range would be between 2000-5500 give or take 500. any help would be GREATLY appreciated!
my dads jobber has a cam from speedpro that cought my eye but i am not too sure of... 222/232 @.050 .479/.501 lift 114 LSA. Would this cam be suitable for my setup? If it is, would my heads accept those lift numbers?
woops, another question, i see that willie is using a 2032 cam, how is the idle on that? lol, what a newbie i am
Old Apr 16, 2002 | 07:50 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Take a look at either the CC305 cam (220/230 on a 114) or a custom CC Xtreme cam .... most notably the 218/230 on a 114 (aka - the "Randy Cam").
Tim
Old Apr 16, 2002 | 01:40 PM
simple's Avatar
thanks for the reply, ill check those out
Old Apr 16, 2002 | 03:04 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
before getting a cam consider what type of boost you are looking to run inf the future and read the following thread; https://www.thirdgen.org/techbb2/sho...threadid=83372
Old Apr 16, 2002 | 03:06 PM
simple's Avatar
i plan on staying at 6lbs for a long long time.....until i can get more funds to buy new things . anywho, i talked to comp cams and this is what they recommended:
PART # 08-304-8
GRIND NUMBER: CS 266H-R14
ENGINE:CHEVY SM BLK 305-350
GROSS VALVE LIFT .500 .510
.006 TAPPET LIFT 266 276
VALVE TIMING OPEN CLOSE
AT .050 INT 5-BTDC 35 ABDC
EXH 48 BBDC 8-ATDC
THESE SPECS ARE FOR CAM INSTALLED
AT 110 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 210 220
LOBE LIFT .3330 .3400
LOBE SEPARATION 114
what do you think?
Old Apr 16, 2002 | 03:09 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I think you should run that by Trevor at vortech before you commit to see what he thinks.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
