Pre-Supercharger questions
Car: 2004 Mercury Marauder
Engine: 4.6L DOHC
Transmission: 4R75
Axle/Gears: 4.10 gears/8.8 rear
I am debating whether or not to do a Supercharger for my car. If I do, I would like to put it on with the current motor and enjoy it for awhile. And in the meantime I will be working on building a new motor.
Anyway, I am looking for input on what to do before getting the supercharger and which ProCharger would do best for what I am looking at.
The car is a 1991 Camaro Z28 with the TPI 305 and 5 speed manual. The motor is all original and has about 165,000 miles on it. I just replaced the original clutch with a new SPEC Stage II clutch and new 3.42 gears and the Torsen take out carrier from SLP will be going in soon. The car currently has March Underdrive pulleys, FastChips chip, cold air intake, TPIS TB air foil, and Borla cat back. And that is about it. It ran a best of 14.7 @ 97mph last year without the pulleys and TB air foil, and with the original, slipping clutch and 3.08 gears.
So the motor seems to be fairly healthy, but does blow a little smoke at start up (valve seals, I am assuming). And the new motor I am planning would be "SuperCharger ready". Planning a 8.5:1 compression 383 with forged lower end, AFR 190 heads, TPIS MiniRam II intake, and CompCams cam.
I am trying to decide on which ATI to go with: either the P-1SC upgraded with the 3 row intercooler, or just go with the D-1SC and run lower boost on the current motor. I would like to run upwards of 15 lbs of boost on the new motor.
So, questions are:
1) What to do on the current motor to help get it ready for a supercharger (will get rid of the FastChips chip and, I assume, the Underdrive Pulleys)?
2) Which ATI supercharger?
I know this was long and thanks for reading it.
So, questions are:
i had to make that same decision about 1-1/2 years ago, i decided on the D1sc, because if i decided to up the boost, the blower is better suited than the P1sc, and yes your fast chips and underdrive pulley's will become paper weights, along with your CAI.
The chip most likely has too much timing advance built into it, the march underdrive pulleys, could be used, but i wll take alot of work and some re-engineering of the crank pulley spacer provided by ATI to get everything thing to line up, i attempted to retain my underdrive pulley's but in the end i installed the OEM pulley's.
Most everyone i have talked with is pleased with the performance of their D1sc, including myself.
hope this helps with your decision.
later
larry
later
larry
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
WIth 165k on it, I would be VERY weary of putting on ANY type of power adder... Chances are youll open up a whole new slew of problems, possible blow by, spinning bearings, throwing rods, etc. And any hint of detonation will kill her for sure.
Car: 1992 Z28
Engine: 383 Miniram
I am a liitle confused on How the Underdrive pullies would cause a problem. I am still trying to pick up on all the info for a supercharger so I am not the best at them. Could some one explain this to me?
first, the spacer for the blower crank pulley will not fit inside the underdrive crank pulley, then once you get past that hurdle, then your alignment of the blower crank pulley to the blower head unit pulley will be off, due to the thickness of the aluminum underdrive crank pulley. understand now? (not being a smartass, just want to make sure)
later
larry
later
later
larry
later
i pretty sure that you can order the oem pulley's thru http:www.gmpartsdirect.com for around $50 total for all 3 pieces.
you just need to get the part numbers of the pulley's
i see that your in germany, if you need me to i can call the local dealer here and get ya the part numbers. or you could post a message for the part numbers on a different forum here on thirdgen.org
later
larry
later
larry
Car: 1992 Z28
Engine: 383 Miniram
Thanks for Offering but, I left the oem in a friends garage in the states and I am willing to bet there still sitting in the same place and he doesnt even know.But if I need them I will post. I wont be rebuilding my engine till I get back to the states next year anyways, But I thankk ya for the help...You wouldnt happen to know a decent place ($) to get a eagle crank and some rods would ya??
