Everyone post pics of your power adder.
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Originally posted by 305q_ta86
Anybody got a towel?
Car: 1991 Camaro RS
Engine: 357cid
if anyhting i would buy a zex nitrous kit.. their plate system is open w/o the bar in the middle for better flow and dispersion. i dont plan on going FI for a while( like until i come upon some money or FI comes down to carb price)
Originally posted by 87Formula4bbl
That is VERY impressive, IMO. I don't know why no one gave it any recognition. That's a sweet setup.
Hey, I just remembered. Didn't you need a number
or something off my Ram Jet motor? I couldn't
remember who PMd me last time about that until
now. I apologize for not getting back to you, my
PC got infected and took weeks to clean up and
reinstall everything! Gotta love the internet!
Car: camaro...????
Engine: 305ci of mouse power
Transmission: 5 speeds of fury
Originally posted by novass
Well here is an updated pic of mine all polished up. Still have to make a custom air intake to pull the air from my power buldge.
Right click...."save as"
Car: 2000 Trans Am
Originally posted by BlownBird
JMatlock88,
Nice!
Verry clean setup!
JMatlock88,
Nice!
Verry clean setup!
No progress pics of mine. Im getting the aluminum sheare3d at work this week for the motor plate and maybe this weekend Ill have the glide and motor bolted together to drop into the car. Going to be alittle bit till I have some good pics
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Heres my current progress. Drove the car a little around the lot. Need to spend a while tuning it when the spindles come back from Indiana. (mustang rack & pinion)
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Would polishing (sanding) the hot side like that reduce its heat disapation by reducing teh surface area? Or would it not be worth mentioning.
Car: 92 Z28
Engine: Boosted LSX
Car: 1992 B4C 1LE
Originally posted by radialtireking
Here's my 434 with a Wilson nitrous pro flow plate.
I don't blame you. Even if I had a 6 second all motor ride I would still wonder what it would do on the juice.
Its like the saying from that movie "Half Baked", but changed around a bit:
"You ever done a bad *** 434??"
"You ever done 434 ON NITROUS!?!?!?"
I had the motor built to use nitrous. I never heard of him being weird about it. He builds plenty of nitrous pro mod motors.
Car: 1992 B4C 1LE
My bad, I was thinking of a different builder, sorry.
work in progress
Since buying a house, $$$ is running low. Making slow progress...Trying to get the damn passenger side headers to fit. I ordered some tubing bends..decided to make my own. Get the rack/pinion set up and finish installing the brakes. I decided to go with N2O(since I have everything) for now and 1-2 years(the old lady will be done with RN School next summer), then the F3M or a 101mm will be going on. I would get more work done in the evenings..buit its damn hot weather. Heres some progress pics
First pic...where it started
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Originally posted by Kenwood
Here is a work in process pic of my turbo setup..Its a reworked version of Guidos original setup..
Car: 06 Envoy, 84 Fiero, 86 Camaro
Engine: 4.2 I6, 2.5 I4, supercharged 355
Transmission: 4L60E, Muncie 4 spd, T-56
Axle/Gears: 3.42's, 4.10's, 3.73's
355, 276/268 cam 1.65 ratio full roller rockers, double roller timing chain, 441 heads, hooker headers, 3" aero chamber exhaust & muffler,Camden 168 blower, 780 cfm Q-jet with all the trics done, Yes there is A/C yes there is Power steering Yes it all works...
Power=sideways through the first 4 gears, lights Lights them up to 45 MPH. only running 4-6 psi right now. my compression islow enough I can run 10 but I will keep to 8 max.
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Thats the twin t3's. Fastest car I've ever driven. Now under construction: wiring, intake, coolant, and exhaust work being done.
Car: 1988 Iroc-Z and 1985 Z28
Engine: Mild TT 355 and Built 383 Superchar
Transmission: Manual
I thought someone would ask. Runs bad *** though... and yes I have two alternators. I did not feel like wasting money on a stupid a/c delete pulley ($75.00) so I threw a old spare alternator to take its place. I am going to redo the t-pipe into a smooth Y, although I know it does not hurt me in any way. I am very happy with my setup's power output.
Kinda confuses people when they see two alternator. I like seeing the look on peoples face when they realize it.
Keep up the great pic posts
