nitrous on ZZ4
Old May 2, 2002 | 10:36 PM
Dauntless's Avatar
nitrous on ZZ4
Does anyone know how much nitrous power the ZZ4 engine can hold? It does have a forged crank, but the pistons are silicon coated aluminum. I'd like to spray maybe a 125 shot. Should I just throw in some forged pistons and go with a bigger shot, or could those al. pistons hold that shot? Any thoughts?
Dauntless
Old May 3, 2002 | 09:54 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Re: nitrous on ZZ4
Originally posted by Dauntless
just throw in some forged pistons and go with a bigger shot Dauntless
sounds good to me and safe too for like 100 to 200 hp shots
Old May 8, 2002 | 07:34 AM
91-ZZ4-Z28's Avatar
If you take all the safety precautions (window switch, good ignition, good plugs, good fuel pump) 125 is fine. But I would not go much higher.
Old May 8, 2002 | 07:45 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
125 shouldn't be a problem as long as you don't go lean.
Old May 8, 2002 | 02:59 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
ZZ4 on Nitrous
The ZZ4 is a pretty tough motor but 125hp shot should be good. Persoanlly I think that a 150hp shot could work well with the proper engine support i.e FUEL PUMP)
When pushing that much HP a MSD 6AL or Equivlent Ignition would be recommended.
Old Mar 17, 2009 | 09:12 PM
85ZzZ4's Avatar
Car: 2005 Chevy Colorado/ 1985 Z28
Engine: fast burn zz4
Transmission: th350
Axle/Gears: 10 bolt (has to go) 3:23 gears
Re: nitrous on ZZ4
stirring up an old thread here i know, but did you ever put the 125 shot through the zz4? i'm looking into it too, i tore my fast burn zz4 down this winter and freshened it up a bit... i replaced the rings with the speed pro plazma molly rings just incase i decided to run nitrous... also i have an msd 6A not the 6AL as mentioned above, will that be a problem?
Old Mar 18, 2009 | 02:39 PM
91-ZZ4-Z28's Avatar
Re: nitrous on ZZ4
I sold my car a few years ago but I did run a 125hp Zex dry system system with a Walbro 255lph fuel pump, Ford Motorsport injectors (it's been a few years I can't remember exactly what lbs rating was), MSD window switch, NOS fuel pressure safety switch, Accell high output coil, one step colder plugs, and a custom PROM, .
I never used more than the 50hp jetting because of traction issues (and that was mostly just for testing and to get a good looking dyno sheet but I felt like it would have been fin at 125hp.
Old Mar 21, 2009 | 07:49 AM
85ZzZ4's Avatar
Transmission: th350
Re: nitrous on ZZ4
thanks, i'm still going back and forth on whether or not i should run nitrous
Old Mar 21, 2009 | 01:38 PM
THE HOFFMEISTER's Avatar
Car: 89 Trans Am GTA
Re: nitrous on ZZ4
Nothing to worry about at all.
Just make sure it dont run lean and you will completely fine.
100hp shot easy, should be fine at 150 really, again, just make sure
it dont run lean and it should be fine.
MAke sure your fuel pump is ok, have you a fuel pressure guage?
Old Mar 21, 2009 | 03:00 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: nitrous on ZZ4
sprayed my old ZZ4 for a while on the 150 tune and fuel delivery is everything
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
