Turbo with MAF TPI??
Old May 8, 2002 | 07:30 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Can I run a turbo on my TPI with MAF? If so, how??
Old May 8, 2002 | 07:32 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
route the air into the MAF, then to the turbo, and then to the engine. or just build it to blow through the MAF because the sensor rate for the stock MAF gets exceeded pretty quick any ways and it will still work like normal.
Old May 8, 2002 | 08:50 PM
CrazyHawaiian's Avatar
Car: too many ...
I sudgest you talk with the guys @ Precision Turbo & Engine (219-996-7832). They sell aftermarket ECU's that will interface with the TPI EFI on our cars (direct plug and pray). I believe their ECU will also control the MAS. You'll prolly have to upgrade to a 76mm or even 80mm MAS.
Old May 8, 2002 | 10:00 PM
Guido's Avatar
Car: 2000 Trans Am
WTF?
Dude, next time research your answers before you give bogus answers. There is only one MAF for TPI, always has only been one MAF for TPI and probably always WILL be one MAF for TPI. There is no upgrading. And even if you could, then you have to overcome the limits in the ECM. It only reads to a certain point then it wont register more air.
Old May 8, 2002 | 10:16 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
sounds like ford stuff.
Old May 8, 2002 | 11:52 PM
Car: too many ...
ok well it was my understanding that with this aftermarket ECU --> the FAST system from Precision Turbo & Engine would control the MAS so it would no longer interface with the stock ECM. I also think it allows you to upgrade to a bigger MAF. But then again I haven't verified this ... just stuff I picked up from reading about aftermarket ECM solutions for turbo applications ... sorry for trying to help out.
Old May 9, 2002 | 12:43 AM
Guido's Avatar
Car: 2000 Trans Am
No as far as I know the only one precision sells is the Speed Pro / FAST and I have it. If they sell something else, it is only useable for Fords or Buicks.
Old May 9, 2002 | 12:48 AM
89ProchargedROC's Avatar
FAST/Speedpro has
ABSOLUTELY NO INPUT FOR A MASS AIRFLOW SENSOR
you either go speed density or alpha-n
Old May 9, 2002 | 02:43 AM
Car: too many ...
alright sorry
Old May 9, 2002 | 12:48 PM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
Originally posted by Guido
WTF?
Wrong. There is one MAF that is compatible with the standard TPI MAF - The Wells SU-145. Better airflow and same characteristics, but uses a honeycomb matrix instead of the hot-wire technology.....
Old May 9, 2002 | 08:25 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
but still doesn't overcome the limits of the ECM which i think the point guido was trying to make..
Old May 9, 2002 | 09:52 PM
Guido's Avatar
Car: 2000 Trans Am
Thanks fly89.
Old May 10, 2002 | 08:34 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
there are some dudes (although a little impatient and cranky) over on the chip burning board (here at thirdgen) that have some pretty good ideas on how to overcome both the flow limitations but also the data limitations of our MAF's. most of it has to do with changing to a later GM computer and harness that has the ability to sense airflow above part throttle (big amounts of air).
Old May 10, 2002 | 09:00 PM
Yes, the 255 gm/sec limitation in the computer is being worked on so it won't be a limitation any longer but they've been working on that for .... ever.
What exactly is alpha-n?
Old May 10, 2002 | 09:13 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Basically figuring there are three main types of EFI metering; speed density (MAP), mass air (MAF), and Alpha-N (basic). It is EFI that is as close to mechanical as it can be. where load is not merely calculated but pre-figured or pre determined and fuel is delivered based on RPM vs. throttle angle with an O2 sometimes being called upon to smooth out the A/F ratio. It is often used in racing and in very radical motors where a vacuum signal is out of the question. the old analog holley projection is a form of alpha-N, and accel, speedpro, and a few other manufacturers offer the alpha-N option at the click of a mouse from the programming screen.
Old May 10, 2002 | 09:54 PM
Thanks for the info. I think that's the reason a friend of mine can run his '89 IROC with stock ECM, no MAF, bigger injectors, 50psi, and N20. He has the stock chip but I think it's running in LHM which would put the ECM into Alpha-N. Very interesting.
Is the pre-determined tables for Alpha-N programmable so if a person wanted to intentionally run their 165 ecm in alpha-n mode they could and still program it to run properly? This would be very helpful for someone like myself that has the 165/MAF ecm and wants to use a turbo? Would I be better off running in Alpha-N or just running a turbo and maxing the MAF at 255 gm/sec. Swapping to SD is not an option for me.
Old May 11, 2002 | 01:23 AM
alpha-n is the BIGGEST PITA to tune
basically you are ONLY tuning on TPS voltage/angle and RPM
it is extremely tough to tune and you just about need a dyno unless you have someone who has tuned alpha-n before
the maps are TOTALLY different
Old May 11, 2002 | 02:21 AM
So what's going to be the disadvantage to maxing the MAF at 255 gm/sec other than the obvious? Also, if I were to install a turbo with the MAF, what exactly would need to be changed in the chip to compensate for the extra air from the turbo?
Old May 11, 2002 | 11:52 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Blowing thru the stock MAF will generate about 6 ozs of plastic chips from the case blowing apart.
If you want to do a blow thru this is how to do it but you have to use a LT/LS1 type MAF. this happens to be an option on the 89 TTAs but none of the others.
http://www.gnttype.org/techarea/engine/mafrelocate.html
Old May 11, 2002 | 11:55 PM
fly89gta's Avatar
Car: 2018 Camaro SS
u mean that's not good for the engine?
Old May 11, 2002 | 11:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
WTF?
Gee, it would be easy to quote you about quoting bad information. The ecm isn't the limit. The software will read to 255, that number isn't grams/sec unless you write the tables that way. Using a GM computer, and what was a 255 grm/sec limited system, I'm running a calibration that allows for 510 grams/sec..
Old May 12, 2002 | 12:23 AM
Using a TPI ECM?? I've gotta see this to believe it. Sorry, I live in the Show Me State.
Old May 12, 2002 | 01:00 PM
So if I can't blow the air through the MAF w/out destroying it then I should be able to get away with putting the MAF before the turbo and sucking the air through the MAF right? I know this will max the MAF due to the sofware limitation, since it's written as gm/sec in my calibration, but it's not like I have much other option at this point in time and I know there's at least 1 person on this board that's running a supercharger with MAF.
89GTAOz
May 16, 2020 09:31 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
NBrehm
Aug 25, 2015 11:49 PM
Bert87
Aug 23, 2015 03:50 PM
Sanjay
Aug 12, 2015 03:41 PM
