Am I safe?
Old May 8, 2002 | 08:54 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
Am I safe?
Ok, my fuel system is good, and my motor burns no oil. I have 83,000 fairly gentle miles on my 305TPI. I want to run a 100shot on it. Do you think I will have any problems? I have looked on this board and I know alot of people ask for the same advice. Sorry to ask again but I haven't seen anybody with my setup. If I install it I will re-install my stock PROM, and retard my timing a couple of degrees. I will also change plugs accordingly. Any help would be appreciated.
BTW: I run a 15.3 now, with a 100 horse shot what do you think I can run? (mods are in sig)
Old May 8, 2002 | 08:59 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
like you said, you will have to lose the chip because it adds too much timing and pulls too much high RPM fuel when on nitrous. the stock chip should work and 14's here you come. run the NX 20920 or NOS 5151
Old May 9, 2002 | 12:16 AM
daverr's Avatar
old setup
my old setup was a 305 tpi with 100 shot 5 speed.well anyway my personnal best times were 13.75@100.100 shot is pretty reliable.
dave
Old May 10, 2002 | 11:46 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Thanks for the input guys. I put up a post like this awhile back, I am just trying to build up my confidence that I probably won't blow my motor as long as I install the system correctly. Not to mention do the few things required to make sure it's reliable. Like I said in my original post I know people ask this question 100 times a week, but everyones motor is a little different in the way it's been cared for, and it's present condition. I think I will go ahead with the N2O install. What systems do you use/recommend?
Old May 16, 2002 | 07:56 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Whats the c/r on that 305 like 9.3:1 ??
I'd think you'd be ok with a solenoid based fuel block valve. (blocks return line, increases rail pressure)..
Nitrous scares me..
-- Joe
Old May 16, 2002 | 10:26 PM
TBI305Camaro's Avatar
cough *headers* cough
86IROC112
Nov 27, 2015 09:54 AM
roysatikas
Sep 22, 2015 08:15 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
UMI Sales
Sep 4, 2015 08:39 AM
