How many seconds will 150HP give??
Old May 18, 2002 | 10:18 PM
gtabadboy's Avatar
How many seconds will I get if I run a 150 HP nitrous kit?? I'm only running 14.82 @ about 94mph! Specs in sig:
Old May 19, 2002 | 09:18 AM
AGRESSIVE RACER's Avatar
If you get GOOD traction and a GOOD 60 Ft. time then a mid 12 should be easy, but if you're only running a 14.8 with those mods then I think a mid to high 13 without traction.
Old May 19, 2002 | 03:31 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
The commonality for wet flow 150 shots is about 1 second to just over 1 second (1.05-1.1) and just under 1 second for dry shot systems (.89-.9) seconds faster. Wet flow systems seem to be measured at the 6#/min rate, whereas the dry systems seem to be fraught with over estimation by the manufacturers and their exaggerated dyno #’s. There are probably some exceptions to this rule. I have seen few faster than I have listed (usually due to optimized combos or altitude), and many slower (usually due to mistune or traction).
Old May 19, 2002 | 11:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
I went from 13.8@102 to 12.52@112mph with the NOS 5151 plate kit on my last z.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Linson
Sep 21, 2015 01:08 PM
earlpote
Sep 12, 2015 11:55 AM
Fronzizzle
Sep 8, 2015 12:10 PM
