NX nitrous and Hypereutectic Pistons
Old May 20, 2002 | 06:41 PM
gtabadboy's Avatar
Can I safely run NX nitrous (150HP) with Hypereutectic pistons?? Someone told me my pistons would turn to dust. Is anyone doing this combo now?? Thanx
Old May 20, 2002 | 07:06 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I'm running those pistons...
make sure you're running a little on the rich side, and no worries...
Old May 20, 2002 | 07:10 PM
gtabadboy's Avatar
When you say rich, what psi are you running for fuel pressure? Did you hook up another fuel pump? Is you nitrous activated by switch or automatically at WOT? Thanx again!!
Old May 20, 2002 | 08:26 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
nos and pistons
yo!! my engine had 142,000 on the clock with 5,000 of that with a 150hp nitrous and they looked perfect when ipulled the motor apart!!! they were stock l98's
Old May 20, 2002 | 11:13 PM
budda's Avatar
Ashes-to-ashes, dust-to-dust, quit being a putty or your pecker will rust! propane is the the choice of power adders! It makes good power and smells like bootwah! think like a diesel, run 21:1 drink some more beer, smoke atilla the hun!
Old May 21, 2002 | 12:15 PM
Blockhead's Avatar
Hey budda... you sound like my long lost brother. Where you been? Boy you just aint been right since momma dropped you on your head years ago.... :lala:
Old May 21, 2002 | 07:25 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
There shouldn't be any problem with the pistons at 150 HP unless your engine is detonating.
Old May 24, 2002 | 08:23 AM
JC93Z's Avatar
Re: nos and pistons
YO!!! The first post said hypereutectic pistons not stock. And how exactly do you know that you ran 5,000 miles on nitrous?? Did you have a different odo for when you used n20?
Old May 24, 2002 | 10:15 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I think he meant 5k miles while the n2o was hooked up to his car
but, as far as my setup.. I'm running 53psi fuel pressure.
I have a WOT switch, FPSS, and a window switch.
For fuel pumps, I'm running an intank walbro 255 pump, with an inline Vortech T-Rex pump.
SVO 24# injectors
Old May 29, 2002 | 06:00 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I ran 100 shot in my stock 305 and used up 25 15lb bottles. I ran the NX wet system with WOT switch, FPSS, no window switch. I run 42 FP at idle and 52 @ WOT. My FP guage has hi/lo mem and never dropped below the 42 lbs ever and the FPSS is set at 40lbs. All good safe tolerances. I started floggin the motor at 90+k miles and the motor ended like this with 140+k miles
If you can get forged pistons if not I'd say 150 is pushing it.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
