Boost!
Old Jul 24, 2002 | 04:44 PM
DickButkus's Avatar
Boost!
ok guys, after my latest trip to pick and pull, i got my turbo from a wrecked chevy sprint, it was the only one they had but hey a turbo is a turbo, im gonna be using some water heater flex-tube since i cant bend pipe, so i'll be making the home-depot run tonight, 1 question i have is how do i hook up my intercooler, do i need to run some ducting from my A/C into it? will this mean i have to run my a/c all the time in order to cool. also theres a small hole on the collar of the intercooler, i cant weld either so i was gonna melt an old ewok action figure over the hole, but i want the spot to be a little darker than the color of the ewok, so i'm just gonna use lando calrisian instead. i think that was my main question, i need to get an ignition system as well, thatll add a few extra ponies as well im sure, i cant quite afford it yet, but ive heard that dipping your plugs in gasoline helps your spark out, so ill be tackling that this weekend ...ok guys keep your ears open for my BOV as you see me fly by!
Old Jul 24, 2002 | 05:11 PM
Bort62's Avatar
Right On, Sounds like your on the Right track!
I prefer To use Plastic Army men insteaf of Ewoks however, They Flow Better...
Old Jul 24, 2002 | 06:59 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Sounds like another mustang cross-over guy. Hey D*ck go back to the blue oval.
Old Jul 24, 2002 | 07:43 PM
DickButkus's Avatar
hey thanks for the help, actually i have one more question, i just got my moates connector, how long do i have to let my chip cool off after i burn it?
Old Jul 24, 2002 | 08:29 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
YAWN!
Old Jul 24, 2002 | 09:05 PM
Bort62's Avatar
You don't need to let it cool Off, Just use an Oven Mitt!
Get that Turbo Going w/ your Custom Chip and you will be Jacked up like a Mother
Old Jul 25, 2002 | 12:36 AM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
wErd to ya *****!
:lala:
Old Jul 29, 2002 | 03:50 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
these sick little ba$%@rds in my town were going to take a stock talon turbo and intercooler and put it on a gutted Metro (with blacked out windows to hose the slow import cars in town down.
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
