Supercharger PROM... no FMU
OK, I upgraded my injectors so I can try to supply enough fuel to my motor without using the FMU. I now have Lucas 42.5 lb injectors. My fuel pressure is 50 psi with the vacuum line off. The FMU is set to its leanest position, so it only adds 1 psi fuel for each lb of boost. I'm still using the MAF sensor. I was just wondering how high others have had to go in the "Power Enrichment vs. RPM" tables of the PROM? I have mine up to 50% now, and I'm still lean. What experience does anyone else have with playing around like this?
1 Post
Car: 1992 B4C 1LE
even though this is a power adder related question I believe the DIY prom section will help alot more.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Curious,
Whats your int and blms under part throttle with that fuel pressure? and whats your injector constant?
-- Joe
-- Joe
toronto formula
11-10-2015 06:17 AM
