Those with vortech or ati kits on the tpi cars, how / where do the bracket bolts / studs attach to the motor ? all to the accessory bracket or to the cyl head ? any to the block, any info or pics would be helpful
B4Ctom1
close
Its been too long on the vortech for me to remember but the procharger uses the drivers side accy bracket and longer bolts
I'm currently installing the vortech bracket; it there is a small bracket and plate that replaces the driver's side factory bracket, and a whole lot of bolts. The alternator is relocated to below the supercharger which is a superior location due to heat and tall valve cover considerations (at least in my case!).
The small bracket attaches to the head (uses all three bolt holes) and then the plate attaches to it, and also to the block via long bolts and some spacers, which also holds the alternator. Pics coming later this week.
Pics would be much appreciated
