Procharger install- how to adjust the fan for SC bracket
Old Sep 21, 2002 | 10:48 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
How do you make adjustments to the driver's side fan to allow installation of the sc bracket?
The fan support need to be slotted to allow it to rotate. Not exactly clear on this. Rotation and where to slot.
Thanks.
Old Sep 22, 2002 | 08:22 PM
maniacc's Avatar
Remove the 2 lower fan mounting bolts on the driversside fan assy, remove the metal clips that the bolts threaded into, slot the holes in the plastic reinstall the metal clips, install the 2 lower monting bolts, your trying to move the fan as much as possible towards the driverside fender for clearance.
Hope this helps ya
later
larry
Old Sep 22, 2002 | 08:52 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Now that I have the SC plate installed I see the reason to move the fan over. The lower pulley on the SC plate rubs the motor housing.
Would it be better to slot the hole on the fan support housing instead of the piece on the body. I guess both will work equaly well once tightened.
Thanks.
Old Sep 23, 2002 | 05:01 PM
maniacc's Avatar
i did both, when i did the fan support mounts, there's not much room for slots, i was able to get enough movement after slotting the piece under the metal clips.
later
larry
Old Sep 23, 2002 | 08:06 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Gotcha!
Thanks for the tip.
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
