anyone ever use AN compression fittings?
Old Oct 17, 2002 | 09:53 AM
downwithET's Avatar
they are called "hard tube adapters" they use a compression fitting, anyone ever use them?
oh yeah, here something funny, this board has prolly already seen it tho... http://www.acsu.buffalo.edu/~attse/honduh.htm
Old Oct 17, 2002 | 10:36 AM
89ProchargedROC's Avatar
i planned on using them to use braided line for the install of his stealthram but decided on using some adapters instead
Old Oct 17, 2002 | 01:27 PM
Twin_Turbo's Avatar
Do you need the AN sleeves for flared alu tubing or the starlite hoses?
Old Oct 17, 2002 | 01:50 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes on any kind tubing, dont know what starlites are
Old Oct 17, 2002 | 04:14 PM
Well if you are planning on just using the hard tube adapters.....no you dont need them
If you want to use a tube nut, then yes you have to use tube nuts and sleeves in conjunction with each other
Starlite hose is the expensive lightweight hose....you can use the special "crimp" fittings aeroquip sells but i wouldn't install them yourself, or you can use the normal AN fittings with that hose
Old Oct 18, 2002 | 04:54 PM
Dan83's Avatar
Yes you need the sleeves. It adds strength to the flare and prevents the nut from damaging the tube since AL tube is alot softer than steel.
Old Oct 18, 2002 | 05:04 PM
Twin_Turbo's Avatar
I guess my sentence was kind of weird, I wasn't asking what to use, I meant to ask what downwithET wanted to use, I couldn't really make up out of his question
Old Oct 19, 2002 | 04:19 AM
um....the sleeve is what seals against the flare what you tighten the nut, if you didn't use it, you'd leak
Old Oct 19, 2002 | 02:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No it isn't. The flare seals against the flared end of the tubing.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
