D-1sc good enough?
Old Oct 17, 2002 | 02:07 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
D-1sc good enough?
I'm kinda locked into this thing now because I own it so suggesting F-1 this or YS-trim now cant help me. If I spin a D-1sc to its safe max rpm, will it be to small for a 415 cid, or should I build it smaller (389 cid)? What kind of boost could I expect on a good flowing motor? I watched a really spun s-trim vortech produce poor boost levels on a 383 LT4 with big (220+cc) AFR heads and now I am wondering.
Old Oct 17, 2002 | 03:11 PM
XxPichulonxX's Avatar
according to ati their chargers were designed for big blocks so small blocks are no prob, vortech is crap because of their low maximum rpm of their cast impellers ati uses billet that withstand over 80,000 rpm (according to them)
Old Oct 17, 2002 | 03:30 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
B4c.. I have a solution.. Sell it to me
You know Ive been trying to decide what to do next.
Old Oct 17, 2002 | 03:44 PM
Bobalos's Avatar
NO, NO, he meant sell it to me, I have a big block. According to ATI they are designed for Big Blocks, so...........
BW
Old Oct 17, 2002 | 11:52 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Old Oct 18, 2002 | 11:49 AM
BlownBird's Avatar
XxPichulonxX
Do you believe everything you read, or are you speaking from experience?
Old Oct 18, 2002 | 12:32 PM
I don't believe everything and don't have $ to speak from experience i'm just saying whatever
Old Oct 22, 2002 | 12:44 PM
LT1guy's Avatar
Car: 1987 Trans Am
I had an S-trim Vortech that was pullied for 15 lbs on a 5.0 Mustang, and never had a problem. You can't always believe manufacturer's hype.
Old Oct 23, 2002 | 11:48 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I saw there was a guy with a bird that had a P600 with a tiny pulley putting out massive boost with no probs too. The whole reason Im asking is because I have a newer P1sc now and for $1k they will upgrade it to a D1sc (they share major parts). I am actually going to shrink my original 415 down to 390 to try to help efficiency.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
