Loudest Supercharger????
Old Dec 8, 2002 | 05:28 PM
my88IrocZ's Avatar
Who makes the loudest supercharger on the market? I am thinking about supercharging, my car, and if I do I want to let everyone know it is there. I love the sound of them to!!!!
Old Dec 8, 2002 | 05:44 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I figure an 16-71 or 18-71 would be the loudest, but you could save alot of money and not have to mess with all that expense and irritatingly masive power just by getting the supercharger stickers and running a pete jackson noisy gear drive....
Old Dec 8, 2002 | 07:34 PM
my88IrocZ's Avatar
It is for a TPI, so like ATI, Vortec, ETC
Old Dec 9, 2002 | 10:13 AM
MdFormula350's Avatar
not sure if its the loudest, however, ati seems to be a great choice!
Old Dec 9, 2002 | 01:11 PM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
Heard an F1 Procharger on a 91 Formula a few weeks ago. OMG was that sucker loud.
Old Dec 11, 2002 | 06:48 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
My Vortech V-1 S-trim is pretty loud. I personally would like it a little quieter.
Old Dec 11, 2002 | 10:11 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
ROFL thats a good one lol.
Old Dec 22, 2002 | 05:17 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
If your talking abouta roots blower, they are all about the same...but the tighter you make the belt the more it will whine
Old Oct 5, 2009 | 02:30 PM
Ryan84TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: Modified 350
Transmission: TCI 700R4
Re: Loudest Supercharger????
Yea I agree, The Pete Jackson Gear Drive is a whole hell of alot Cheaper!!!!!.......SOUNDS KOOL 2!!!!!
Old Oct 5, 2009 | 02:37 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
My brother's 92 RS has an F1A with the cog drive. That is one loud SOB! There is no denying it has a supercharger.
Old Oct 5, 2009 | 03:01 PM
Beater79TA's Avatar
It's not that loud.... it only sets off car alarms....
But, yeah, a cog driven F1A is a level of loud you just have to experience.
But to the OP, if you're planning on racing people with it vs. just intimidating them out of racing you, loud is the last thing you want. Mine is set up the way it is because I enjoy scaring small children, housepets, and the non-automotive minded just by having the car running near them.
Old Oct 5, 2009 | 04:15 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
LM F'in AO!!!!!!
Old Oct 5, 2009 | 07:46 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
not to highjack but beater you have any pics of your f1a on your car??would like to see how it fits
Old Oct 6, 2009 | 08:33 AM
Beater79TA's Avatar
Willie used to have a thread on here about how well they fit. But I'll try to take a few shots and post them up tonight. It's the same physical size as the D1SC and uses the same bracket. It is quite a bit louder though. Especially with the cog drive using the ATI blower cog with the clutch drive setup in it.
Old Oct 6, 2009 | 12:16 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I don't think you have to worry about hijacking, this thread is 7 years old. The guy has probably already bought a supercharger and sold the car to put his grandchildren through college.
Old Oct 6, 2009 | 04:27 PM
tom86iroc's Avatar
Car: 1986 iroc
i saw willie's thread but his pics werent to clear or showed a wide angle shot i have a d1sc setup now but im thinkin i want to go f1 now with a cog setup
Old Oct 6, 2009 | 04:32 PM
Fitment is pretty good, the only issue is the cog setup makes the radiator neck a VERY TIGHT area.
To make life easier he had a radiator done up with a custom outlet that comes out on of the side of the tank and goes up, instead of coming out toward the alternator. You have to see the pics. Works beautifully.
Old Oct 6, 2009 | 05:39 PM
Beater79TA's Avatar
The blower fits just fine. It isn't physically any larger than the D1SC. Getting a large enough air filter on it is another question since it moves a lot of air when it's spun up.
Running the cog setup makes fitment of the upper radiator hose an issue depending on exactly which cog and radiator combination you use. The ATI sprag clutch one is thicker than the Procharger ones and makes it that much worse. Getting cooling fans to fit is the other problem and you will want to invest in low profile aftermarket fans to clear the cog belt idler pulleys. The cog drive will also require removal of the Wonderbar off the car if you are using one of those.
And finally, if you thought the ribbed belts were expensive, the cog belt I'm using lists for close to $200 so have an open mind and open wallet when you move to the cog setup.
Old Oct 6, 2009 | 08:44 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
I have an old idler pully that screams bloody murder.. Sell it to you for $15 shipped. Everyone will wonder what the he!! you have under the hood.
Last edited by TexasSilhouette; Oct 6, 2009 at 08:45 PM. Reason: Fix all my fat fingered typos!
Old Oct 6, 2009 | 09:50 PM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
gotta weiand 144 that has a nice unearthly whine when i tromp the secondaries open. definently audible to those around me
Old Oct 7, 2009 | 03:15 PM
tom86iroc's Avatar
Car: 1986 iroc
3rd gen and beater thanks for the info i have a be cool rad setup and a swivel water neck we're a speed shop so we can fab stuff up if we need too thanks guys and is your car carb or FI?
Old Oct 11, 2009 | 03:49 PM
Beater79TA's Avatar
Here's the pics I promised a week or so ago... I think I'm past the point of needing anything else fabricated... at least I hope I am. The radiator had to be re-done to fit past the ATI superpulley. If anyone wants one, the CAD file is ready to go at Ron Davis Racing and you get to pay less than I did...
Now I just need to finish routing the air intake because that little filter just isn't going to cut it. And maybe a longer upper radiator hose so I can tie it down better to the top of the radiator.
Old Oct 11, 2009 | 03:51 PM
Beater79TA's Avatar
Forgot to mention this in the first reply... The BeCool is nice ( I tried one of those in the car first ) but it will not clear the upper radiator hose if you retain the AC and use the sprag clutch cog pulley from ATI. It will fit (tightly) with the Procharger cog pulley's though.
Old Oct 12, 2009 | 06:43 AM
tom86iroc's Avatar
Car: 1986 iroc
SWEET that's what my cars gonna look like when its done HSR and all now those are the PICS i was looking for lots of detail for me to work with THANKS man now the is that an f1 f1a casue ive heard alot of different versions from here and that doesnt use the lil brace from the charger to the alt?
Old Oct 12, 2009 | 11:48 AM
Beater79TA's Avatar
Yes, that is a F1A in all its polished glory. it doesn't use the brace from the charger to the alt because there isn't a hole in the bracket for the brace to bolt through. It came with the brace, just no way to bolt it to the bracket. There are other braces in place though at the bottom of the bracket to the engine block and the corner just below the charger back to the side of the engine block to lock the bracket solidly in place. If you'd like, I can try to get pictures of those. I believe they are still available from ASSC Racing or you could try to fab your own version.
Also, if you're going HSR, here's your warning. HSR + poly motor mounts = cowl hood required. Rubber mounts or, maybe, solid mounts you can likely get the stock hood back on, but the poly mounts left me needing about 3/4 inch extra clearance at the throttebody to close the stock hood and the stock hood didn't have that much material to remove without cutting a hole completely through it.
Old Oct 12, 2009 | 12:04 PM
tom86iroc's Avatar
Car: 1986 iroc
i think that is only on the firebirds that occurs on awesome pics thanks for the info GREAT oh and thats a d1sc bracket?? the d1sc bracket i have now has 2 holes right where the bracket should bolt too
Old Oct 12, 2009 | 01:18 PM
Beater79TA's Avatar
Trust me on this one.... at least on my Camaro, the HSR + poly motor mounts meant the stock hood was not going back on. I have seen other Camaros with rubber motor mounts, the HSR, and a stock hood though. And I wouldn't even want to try and put a HSR on the GTA I've got. It's getting a Miniram instead.....
The bracket is from a D1SC kit and the F1A bolted right in. The brace to the alternator does not have a spot to put it so I just didn't use it. I'm not worried about it either with the other bracing that is in place to make the bracket more rigid.
Old Oct 12, 2009 | 02:40 PM
tom86iroc's Avatar
Car: 1986 iroc
damn ok i might be in trouble now lol and thanks for the info on the alt bracket just double checking the strength of the bracket dont wanna any breakage issues
Old Oct 12, 2009 | 08:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Even with the energy suspension engine mount inserts inside the stock mount casings on my B4C, a Accel Super Ram did not fit. It hit the wiper motor. I had to use stock mounts.
Old Oct 13, 2009 | 11:38 AM
sailbrd's Avatar
My D-1 whines pretty good. A little trick to take the edge off is to get a stick of wheel weights and stick them to the gear box housing. Gets rid of some of the higher pitched sounds.
Old Oct 13, 2009 | 01:27 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
My vortech is real loud but I have it pullied to the max. Its alot quieter when I spin it slower. It whistles the loudest at idle and almost hurts my ears with the hood off.
Old Oct 17, 2009 | 05:46 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
You interested in selling your D1 Kit at all?
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
xxx3man`
Sep 23, 2015 10:37 PM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
