Drag Racers Please help!!!
Old Dec 20, 2002 | 05:56 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
this probably isnt the best place to post this but I knew this is where I could get a hold of very knowledgeable racers.
I have a chance to get some Drag radials and was wondering if the tire size of these tires would fit in a stock 86 IROC (Clearing fenders well etc.) Will they fit right in or do I have to modify the chasis to make these fit?? Should I get them or not
The Tire size is 11.5/28.5-15 firestone Drag Radials w/ a # that reads PT-80 on the edge near the bead (what does PT-80 mean?)
Old Dec 21, 2002 | 10:43 PM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
I'm not sure what pt-80 means but that is the same size tire I run on my car only I run MT's.
Old Dec 22, 2002 | 10:46 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
did u modify your fender wells or chasis at all??
Old Dec 22, 2002 | 01:55 PM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
No they fit fine. I previously had 17x9 SS wheels on the car and banged in the inner fender but only a little. with the drag suspension in it it is so flexible that the wide tires rubbed just a tad but I haven't had a problem with my slicks.
Old Dec 22, 2002 | 05:00 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
They should fit fine. You might want to consider rolling the fenders though.
Old Dec 22, 2002 | 05:59 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
How do you "roll the fenders". I'd like to go to a bigger tire, but I don't want to tear them up on the sheet metal.
Old Dec 22, 2002 | 06:52 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Can someone post a picture of their car with "rolled" fenders or chasis modifcations to fit a drag slick
Old Dec 23, 2002 | 08:09 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
I haven't rolled the fenders on my formula yet so sorry no pics : (. I did it on my 82 t/a but someone was nice enough to rear end me so it's long gone by now. Any ways to roll the fender you take a wizz wheel or a hack saw or something and put cuts in the lip on the underside of the quarter about 2-3 inches apart and then bang the lip up with a hammer. It isn't hard but if you aren't careful you can crinkle the profile of the quarter - just make sure you put enough cuts in and mke sure they go all the way to the wall of the quater.
Old Dec 23, 2002 | 01:03 PM
83 Crossfire TA's Avatar
I would avoid any cutting if you can, you’re just asking for rust and other problems and the rear quarters are a structural part of the body so in a high powered car you could even end up with some tearing.
The best way to do it is to get 3 people and a baseball bat. One goes behind the wheel, one holds the bat between the lip and the tire and you pull the car forward and back and the bat will roll between the lip and the tire forcing the steel up and against the inside the quarter. Once you get it started the 3rd person sits on the back of the car to add some weight to help the process (you’ll find that you’ll be able to lift the body with the process otherwise and not get much rolling). I’ve done it with a piece of 2.5”, 16ga exhaust pipe also, but it’s much more difficult because it doesn’t grab the metal like a wooden bat will.
Old Dec 24, 2002 | 01:07 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I say,"go for it its only metal....."
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
JSDaddy189
Sep 26, 2015 03:50 PM
aharvel50
Sep 21, 2015 07:31 PM
Amillionoh7
Sep 5, 2015 11:44 PM
