update on tt project
Old Dec 30, 2002 | 11:20 PM
superirocz's Avatar
I have pics if someone want to post them i can email u with them.
I finished the fabricating of the headers/plumbing
IC is finished and in
turbos are fresh
put solid motor mounts in
Oil return and feed lines done
gas tank was welded (sump) Fuel rails modified
All parts of fuel sytem need installed-- aeromotive -12 filter to eliminator pump -10 filter after pump to y into fuel rails -6 and then to regulator and -6 to tank
72# deka injectors done
6 speed tranny and spec III clutch will be ariving any day freight
I just need to plug the DFI 7.0 in and finish the fuel system install tranny. The computer is the only thing not paid for yet. I plan to have it running by the end of Jan.
Old Dec 30, 2002 | 11:46 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Looking forward to seeing this thing.
How big are the pics? You can just attach them if they aren't huge.
Old Dec 30, 2002 | 11:53 PM
MdFormula350's Avatar
sounds great!
Old Dec 31, 2002 | 12:02 AM
superirocz's Avatar
they are huge
Old Dec 31, 2002 | 12:30 AM
superirocz's Avatar
http://community.webshots.com/script...bumID=59100089
Old Dec 31, 2002 | 12:33 AM
superirocz's Avatar
http://community.webshots.com/scripts/controlPanel.fcgi
Old Dec 31, 2002 | 12:44 AM
superirocz's Avatar
2nd link works
I will need a BOV maybe a HKS or that big ATI
Old Dec 31, 2002 | 07:48 AM
Dan W's Avatar
Its not working. Can you post your user name so I can search for it.
Old Dec 31, 2002 | 09:47 AM
superirocz's Avatar
mattb153
Old Dec 31, 2002 | 11:05 AM
Dan W's Avatar
This link worked for me:
http://community.webshots.com/album/59100089KoluKA
Looking good!
Are those S-10 headers? Why did you need the right angle between the header and the turbo on the passanger side? Any chance you could get a couple of top-down and maybe bottom up shots where the down pipes go past the headers on their way out?
Old Dec 31, 2002 | 11:14 AM
bhaas's Avatar
Right on. Looks kickass. How soon till you drive it? Keep up the good work. Are you using wastegates or just a BOV?
Brad...
Old Dec 31, 2002 | 04:26 PM
superirocz's Avatar
I'am using the actuators for now if brady used them on his car then i thougt they would work. I may change to external wastegates and then i would move the pass turbo just like the driver side for a clean look, the actuator would not clear the belt pulley etc so that is why its moved away from the engine(messy). yes I will run a HKS BOV or ATI I just need to buy the BOV and 7.0 DFI and its done. Should run by the end of Jan. i will get some better shots
Old Dec 31, 2002 | 04:27 PM
superirocz's Avatar
s-10 headers
Old Dec 31, 2002 | 07:06 PM
Dan W's Avatar
What heads and cam are you running? What about your short block?
My setup is nearly where you are at. Victor JR -w- 72# injectors, AFR 195's DFI gen VII. Its runing now but w/o the turbos. I've got a pair of PT 51's with terry houston down pipes. I'm about done with my flanges... Tomorrow I should be able to finish them and get the primary tubes swaged so I can get them welded at the end of the week. I'm using weld els for mine.
Old Jan 1, 2003 | 05:01 PM
superirocz's Avatar
trick flow heads Super ram intake and a real mild cam. I dynoed 321rwhp and 390rwtq
Old Jan 1, 2003 | 08:05 PM
bhaas's Avatar
Are those dyno numbers with the turbos?
Brad...
Old Jan 1, 2003 | 08:56 PM
superirocz's Avatar
no that was this summer that pushed my car to a 12.7@111mph on DRs
Old Jan 2, 2003 | 12:26 AM
89ProchargedROC's Avatar
what size cooler you end up with?
Old Jan 2, 2003 | 10:18 PM
superirocz's Avatar
25 wide 16 tall 3.5 thick
Old Jan 2, 2003 | 11:10 PM
87transam5.7tpi's Avatar
what turbos are you using? looks good
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
