Question 1: tpi computer and turbos
Old Jan 8, 2003 | 07:02 PM
bEtUr4dRustang's Avatar
Hey all
I am getting fairly serious about a set of turbos for my 87 camaro. I had a question regarding the computer though. Currently i am running a carb with no computer but i have a complete tpi system under my work bench and i would really like to use that with the turbos. What sort of computer work do i need? I realize a "regular" performance chip would probably advance the timing too much for blown applications but is a stock chip and ECM capable of handling the car running under boost. This is a MAF system. Do i need to run any special sort of computer like a Kalmaker? I want to run about 9 lbs boost...although maybe more if i get an intercooler.
Old Jan 9, 2003 | 12:28 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
You would need to buy a aftermarket ECM (Electromotive, accel, FAST or similar) or change to a 7749 ECM and reuse your TPI harness. Do a search on PROM board for 7749 and check out this link http://www.speedtoys.com/~bort62/7749/Main.htm
Old Jan 9, 2003 | 10:01 AM
thanks
i found that link somewhere on this site after i made this post and was just looking through it.
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
