Car stalls after boost
Old Jan 16, 2003 | 10:21 AM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I have an 87 Z28. First I will give you the vehicle specs, then I will describe the problem.
305 TPI
SLP Cam ( Duration 206/212 Valve lift .480/.487)
Accell 30# injectors
MSD 6BTM ignition
Paxton supercharger 8 PSI
3.73 rear gears
Flowmaster cat back exhaust
Stock exhaust manifolds
Year One PROM calibrated to above specs
Now the problem:
The car runs fine hot and cold, until I run it at full throttle. Under WOT black smoke comes out the exhaust( running rich) but the car responds well. After this the engine begins to miss and stalls out at idle. It is hard to restart and will not idle. After the engine cools down, it runs fine again. I know the injectors are large for a 305, but I contacted Paxton and Summit prior to purchasing them and both felt they would work with the proper PROM. The timing is set at 6 DBTC and fuel pressure is at 45 PSI. Compression is between 90-110 on all cylinders. If anyone has any ideas, I would like to hear them. Thanks.
Old Apr 12, 2003 | 10:42 PM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
It was the O2 sensor. Car runs fine now.
Old Apr 12, 2003 | 10:46 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
