Some progress today...
Old Jan 18, 2003 | 07:09 PM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
tell me what ya think
Old Jan 18, 2003 | 07:10 PM
Balael6's Avatar
Car: 1988 Formula
and this
Old Jan 18, 2003 | 07:14 PM
MdFormula350's Avatar
looks like its coming along great!
Old Jan 18, 2003 | 08:05 PM
Balael6's Avatar
Car: 1988 Formula
Kind of, heh. The driver's side header is about a 1/4 inch higher then the passenger, and the passenger side is about a 1/4 inch too high anyhow, so tomorrow, gonna get the torch out, heat some serious pipe, and move em both down to about an inch lower then they are now to clear the stock formula hood.
PJ
Old Jan 18, 2003 | 11:25 PM
89ProchargedROC's Avatar
lookn' good
Old Jan 19, 2003 | 09:39 PM
Balael6's Avatar
Car: 1988 Formula
Might as well ask first before I start measuring and comparing...
I'm looking for a radiator that fits IN the core support, instead of leaning against it, has anyone ordered an oem replacement for this purpose? and if so what vehicle was it out of? I'd rather just buy a new radiator, since it's about 10 degrees here in michigan, not the best weather to be measuring radiators in a junkyard.
PJ
Old Jan 20, 2003 | 11:36 AM
Dan W's Avatar
Thats a fairly clean looking way to do a header to TT conversion. And look at those headers... if someone wanted to make a tuned header setup they would be perfect, just cut off the stock collectors and run 4 tubes forward to a collector voila Tuned twin turbo header.
Curious, how are you going to get the exhaust out of the car
Old Jan 20, 2003 | 11:57 AM
what he should do is turned those exhaust housings around and have the downpipes face inward toward the center of the motor and run the exhaust under the k-member. Twin 2.5" pipes should clear fine
Old Jan 20, 2003 | 12:04 PM
Balael6's Avatar
Car: 1988 Formula
Thanks. The next time I do this will be much easier, and the headers will look a lot better, since I would just get rid of the collector itself, and just use the 3 inch bend as a collector.
Exhaust...
::laughs:: Actually that is what I'm doing with the exhaust, it's going to be twin pipes, under the k member, not exactly sure where yet, but obviously the least amount of ground clearance lost is where they're going to go, then back into the stock exhaust for now. It should work out quite nicely, and quite cheaply...
Now, next thing to get is a car NOT from Michigan, that isn't rusting from underneath. Ah well, when I rebuild this motor, i'll clean it up, but for now just want to get the motor done.
PJ
Old Jan 20, 2003 | 12:58 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I really like yours. will the fact that the collector portion of this pipe is so large instead of tapering down to a size similar to that of the opening on the turbo?
Old Jan 20, 2003 | 01:15 PM
Dan W's Avatar
Lol, dude is that a sentance?
Old Jan 20, 2003 | 01:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
um I see, would that be a "syntax error"?
Old Jan 20, 2003 | 01:29 PM
Dan W's Avatar
I must have read it like 6 times thinking to myself damn I must be tired.
Old Jan 20, 2003 | 01:30 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
no dude its me not you, the question is to the effect of the collector pipe sizing over a tapered pipe.
Old Jan 20, 2003 | 01:35 PM
Balael6's Avatar
Car: 1988 Formula
Not sure if this answers your question, but here we go...
The collector was cut off from the headers, then welded back on to where it is now. I ordered a mandrel bent 3 inch pipe from jegs, cut it in half, and used that as the rest of the header.
The halved 3 inch bend took some finagling to get inside the collector to be welded, which is why I believe the collector could just be left out of the equation with a welder with very little experience.
Also, there is a 3inch to a "2 and a 1/2 inch" reducer welded inline right before the turbo, which is the perfect size to weld to a t3 flange.
PJ
Old Jan 20, 2003 | 08:55 PM
bhaas's Avatar
Looks nice and clean. What kind of headers did you use?
Brad...
Old Jan 20, 2003 | 10:03 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I better keep a close eye on whats goin on here cause this is what I'm going to be doin soon
Old Jan 20, 2003 | 10:25 PM
Balael6's Avatar
Car: 1988 Formula
The headers are Heddman headers for 55-65 Chevy 2WD trucks.
Hopefully this weekend i'll have the intercoolers in, and both turbo's mounted at an angle like they need to be, but we'll see since my computer is on the way and that's going to be a blast rewiring.
Heh, if you have any questions, i'll be sure glad to try and help.
pj
Old Jan 27, 2003 | 12:35 PM
Balael6's Avatar
Car: 1988 Formula
Ok got the computer, and the repinning diagrams all figured out. Need some help though guys. I'm looking for a new knock sensor, memcal, and a 2 bar map sensor. Are these the correct part numbers for a 90-92 305 SD setup? and for the syclone map?
Knock sensor - no idea
Map Sensor - 16009886
Memcal - 16163139
Are these right for the 305? i found quite a few topics for 350's, but none for 305's. Thanks guys.
PJ
Old Jan 27, 2003 | 01:25 PM
Guido's Avatar
Car: 2000 Trans Am
Try hitting up the DIY prom guys. They would be able to help you out there Im sure.
Old Jan 27, 2003 | 01:28 PM
Balael6's Avatar
Car: 1988 Formula
::smacks himself:: heh, oops, wasn't even thinking. Thanks man.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Cornholio7979
Sep 20, 2018 02:31 AM
gta power
Convertibles
Sep 23, 2015 09:32 AM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
sailtexas186548
Aug 26, 2015 03:32 PM
