Help- 87 & 88 Tpi Engines
Old Feb 8, 2003 | 06:44 PM
gtaguy87's Avatar
Car: 1998 Ram Air Trans am
Engine: Ls1
Transmission: 6 speed manual
I have and 87 GTA with TPI and I want to supercharge it, I was looking at Prochrager cause they seem to be the best but they claim that the kit will only work on a 88 and up TPI. I was wondering if anyone knows the differences between a 87 and 88, externally that would cause that. I need some advice on what to do here. Thanks in advance
Old Feb 8, 2003 | 07:04 PM
Jack G Jr's Avatar
first thing first does your engine use a v belt or serpintine?if it has the v belt you have to change over
Old Feb 8, 2003 | 07:15 PM
gtaguy87's Avatar
Engine: Ls1
im not sure its a 5 speed manual with ac does that help
Old Feb 8, 2003 | 07:16 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I believe the only reason you can't use it is your accessory setup. Change over to a serpentine setup and you're good to go.
Old Feb 8, 2003 | 07:25 PM
gtaguy87's Avatar
Engine: Ls1
how much does it cost to change over
Old Feb 8, 2003 | 10:02 PM
Jack G Jr's Avatar
you could try your local gm dealer or a salvage yard like third gen resourse or hawks e-mail either one they have been helpful to me should have what you need
Old Feb 9, 2003 | 10:20 AM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
just post in the for sale section, wanted tuned port surpentine setup, or PM wtg3575 , i can almost guarantee he will have one...
Old Feb 9, 2003 | 05:24 PM
gtaguy87's Avatar
Engine: Ls1
what kind of different parts does it entail?
Old Feb 9, 2003 | 10:56 PM
Jack G Jr's Avatar
just the pulleys and brackets along with the belt tension this move your a/c & alt to switch sides when you get a chance checkout willie's home page i believe he has an 86 or 87 and had to do the samething
Old Feb 10, 2003 | 11:51 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
and the p/s pump and new water pump and i got the a/c delete and deleted the smog.
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
