O2 senors with turbos
Old Feb 10, 2003 | 08:11 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Hey Guys,
I have asked this question before. But is there any special o2 senor you can get to measure o2 levels for each cylinder of a v8 with twin turbos?
Any ideas or other thoughts?
thank you
Old Feb 10, 2003 | 09:54 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I would think yer best bet is to go with a individual EGT setup.
Just MHO
Kat
Old Feb 11, 2003 | 08:39 AM
ATOMonkey's Avatar
Sure there is. All you need is eight of them.
FYI modern engine controllers can measure instantaneous crank speed/acceleration and compare that to O2 readings to determine if a cylinder is running rich or lean, and then adjust accordingly.
Old Feb 11, 2003 | 06:03 PM
Trux's Avatar
Transmission: t-56
Umm...
I know it is possible without turbochargers. But do you need special sensors to use with a turbo. I was told o2 sensors are pressure senitive so should not be used before the turbo.
Old Feb 11, 2003 | 06:33 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I typed this in your other thread about O2 sensors, but anyway, the O2 sensor is before the turbo in the TR's and TTA's and works fine. You can also build a wide band for about $200. I believe the Buick guys place them farther down in the downpipe. If you're really interested do a search over on turbobuick.com. Look for posts by Bruce (Grumpy over here).
Old Feb 12, 2003 | 05:31 PM
Trux's Avatar
Transmission: t-56
oh
I have not been getting any emails about someone posting. Thanks for letting me know.
I will look around for that.
thank you
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
