Nitrous remote bottle opener
Old Feb 13, 2003 | 11:32 AM
B4C Hawaii's Avatar
Anyone here using one of these, how do you like it? Any problems with the installation? Thanks.
Old Feb 13, 2003 | 06:52 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
if you get one you may consider getting the NX one, as well as a GEN-II kit from NX, and the switch panel that is offered from them to tie it all together. I have installed a few of these and wow it is nice.
Old Feb 16, 2003 | 10:21 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I'm using the NX remote opener.
Very nice product.. (If you have the $$ to spend..)
The NX unit literally opens and closes the bottle valve, where as the NOS one (and other brands) are just a solenoid mounted on the nipple.
You can achieve the same thing as the NOS "opener" for a cheapo $60 nitrous solenoid...
Old Feb 16, 2003 | 11:17 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I guess I am running the inferior NOS opener. Install was simple. No probs with function.
-Schultzy
Old Feb 16, 2003 | 11:45 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
-Schultzy
I didn't mean for my post to be offensive. From what I've read, people have a lot of problems with the NOS openers leaking.
Old Feb 16, 2003 | 11:49 PM
Car: 1989 GTA
No prob bud - your post was not offensive. After reading your description I was just giving my opinion. Not offended at all. The NX sounds like a nice piece.
With the bottle mounted in the spare tire area, I just had to have a remote regardless of brand.
-Schultzy
Old Feb 17, 2003 | 12:43 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I'm trying to find a spot to mount this big 15lb bottle.
I'm almost tempted to see if I can find someone that wants to trade a 10# for my 15#....
Is your bottle a 15# in the spare well? I know you can stuff a 15# & an opener into a 4th gen's spare well. I can't find any info on doing the same in a thirdgen.
Old Feb 17, 2003 | 01:57 AM
Car: 1989 GTA
Mine is a 10lb bottle. There is a bit more room in there but I have not seen a 15lb bottle up close so I am not sure how much larger it is. I created a bit of a platform to mount the bottle brackets on. It is about 3.5 - 4 inches above the bottom of the well. You could probably go even higher and that would give you even more room.
-Schultzy
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
