Cold Air Induction??
Old Mar 14, 2003 | 11:35 AM
Kaas's Avatar
Car: 89 Iroc-Z
i was wondering if it was possible, and if so, how hard would it be to put cold Air induction into a 3rd gen camaro
Old Mar 14, 2003 | 12:23 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Yep, it's done all the time.
If you do a search I'm sure you'll come up with a lot of different setups.
I believe it's SLP that makes a cold air intake... though many people just make their own setup. I made a "Cold Air Intake" out of PVC pipe and a cone filter. Which, really is not a cold air intake since it isn't blocked off from the engine heat... more of an open element filter on an improved intake arm.
There are a lot of people who have actually routed the intake arm down below the hot engine air and have it sealed off so that it only takes in the cool air below. The aftermarket setup I mentioned is like that also.
Old Mar 16, 2003 | 11:35 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
heres a pic of mine that i made only cost about 15 bucks not counting the filter, and its routed to a hole i cut out under the battery box were the filter is.
you can see more at:
http://darcom.org
Old Mar 16, 2003 | 01:50 PM
MdFormula350's Avatar
nice pics!!
Old Mar 16, 2003 | 07:40 PM
Kaas's Avatar
Car: 89 Iroc-Z
thanks for all the pics and examples...also, i will prolly be doing it with a L98 and TPI, if that is able to be done...if so, how much harder or such would it be to do that?
Old Mar 17, 2003 | 01:39 PM
bEtUr4dRustang's Avatar
The first car is TPI, the second one is running a Super ram but the Throttle body is in the same place as any TPI car.
I don't get what you are asking...
Brinkkl2000
Aug 4, 2018 08:29 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCtometal
Sep 2, 2015 02:01 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
kyle5647
Aug 15, 2015 11:56 PM
