Speed Density and Supercharger
Old Apr 9, 2003 | 04:27 PM
mat89RS's Avatar
Guys, got a few questions, I'm new to this stuff so I could be wrong in the way I explain it ...
1. I want to get 6 psi out of my M112 Eaton blower, if I use a 12:1 FMU will that work or do I need like a 8:1 ??
2. Do i have to reprog the ecm ? if so, is it just better to convert to 749 and work without the FMU ? can 749 work with lt1 ??
3. Do I must use a boost retard box or it's not neccesary ?
4. are 21# injectors too small to supply my LT1 with 6psi of boost ?
Old Apr 10, 2003 | 07:46 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The 93 ECM MAP input wont see boost, be better off with the 747 setup, you'd have to get the intake drilled for a distrib, but other than that it'd work.
th 21# intjectors, way too small, try some 30 lb svo's, maybe 24 svo, how are you planning to mount the thing to your LT1 ?
Old Apr 11, 2003 | 10:29 AM
mat89RS's Avatar
I'd like to keep the optispark on the my car since I got rid of all my tpi stuff including the ecm, wiring and distributor.
is there anyway to keep the 93 ecm without a FMU or aftermarket Fuel injection system that supports 2 BAR???
I'm planning on running the Eaton supercharger on top of the passenger side valve cover and have the pulley straight where the alternator is, then, relocate the alternator where the ac-delete pulley is.
Old Apr 11, 2003 | 10:44 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
is the 747 the later MAF LT1 ECM anyways?
Old Apr 11, 2003 | 11:07 AM
TransAm86's Avatar
2 options that "I" can think of:
1. Get a 94+ ecm. Convert to MAF. Then get a calibrated MAF to the injectors of your choice. I'dd say 36# and more. $$$$$
2. Get an FMU, 10:1 or 12:1. that will be more than enough to provide for 6 pounds of boost with your stock injectors.
For your timming problems build a water/alky injection sys that comes on at 3 pounds. That will prevent detonation.
Nik
Old Apr 11, 2003 | 11:12 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
there is that other system that allows use of injectors on the TB that sprays extra fuel for the boost, but we are just talking about a 6 pound boost right, lets not build the space shuttle. If an FMU is good enough for the blower manufacturers up to 9 lbs (and MORE!) then why not use an FMU?
Old Apr 11, 2003 | 01:55 PM
mat89RS's Avatar
ok well FMU might be the way to go but will it give me horrible gas milleage ???? since the fmu will be always adding fuel to the system ...
or does the blower will only create significant boost over 1800 rpm ?
Old Apr 11, 2003 | 02:06 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
FMU only adds fuel when there is boost just like any other type of system
Old Apr 11, 2003 | 02:54 PM
mat89RS's Avatar
Yeah, knew that but my question is, does a SC or blower creates boost on an engine that is at idle or when it's reving under 1800 rpm ?
Old Apr 11, 2003 | 05:26 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
It never makes any boost if the throttle is closed regardless of the engine RPM.
Old Apr 11, 2003 | 08:45 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
well put
Old Apr 12, 2003 | 02:15 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Speed Density and Supercharger
1) I know several dozen people now that have eventually tossed FMUs and gone with the **proper** ecm to get the fuel and timing corrections right.
2) 749 won't work with an LT1. At least not with out getting creative.
3) Doing things properly will get you proper results, ie forget the retard box.
4) yes they are too small.
One of the real problems with the Optispark is the air gap between the cap and rotor. That eats up alot of ignition nergy and wears out parts unnecessarily fast.
Going with a Distributor and 749, would be my best suggestion.
Or
Get the old check book out and invest in a GOOD aftermarket ecm.
Old Apr 16, 2003 | 10:53 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
will the commander 950 work with his application?
its the cheapest one i know of, and the easiest to tune boost with. just a thought.
Old Apr 17, 2003 | 12:31 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I dont see why not, I might be doing it myself...
Old Apr 17, 2003 | 01:34 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Yes holley does offer one ready for the LT1.
Old Apr 17, 2003 | 03:48 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
turbo
you can use the syclone/typhoon ecm's
they also used a 3 bar map sensor also
they were a speed density setup also
Old Apr 29, 2003 | 06:20 AM
Dr G's Avatar
What does FMU stand for?
From reading I know it bumps up fuel pressure in relation to boost at a ratio of about 6 PSI of fuel pressure per PSI of boost and is a mechanical/analog device that adds this needed extra fuel by increasing fuel pressure.
Old Apr 29, 2003 | 07:04 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Fuel Management Unit.
Yes it is boost referenced, and adds additional pressure to the injectors during boost. (basicaly shuts off the return line to the tank)
Bob
Old Apr 29, 2003 | 06:13 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
FMU raise the fuel pressure at different factors.
A normal F?P regulator increases fuel pressure 1:1 for every one pound of boost the fuel pressure goes up one PSI.
An 8:1 FMU means for every pound of boost you get 8 pounds of fuel pressure.
There is a sometimes huge problem.
A fuel pump will generate only so much work so as you demand it to work at a high pressure, the less volume you may develope. Which means you lean out just when it is the worst time for it to.
Much better to use larger injectors and 2 bar ecm.
Saturn 5 has posted in Power Adder about just getting his car running with the twin M90s and a 749 ecm,
Old Apr 30, 2003 | 04:09 AM
Dr G's Avatar
Thanks Bob and Grumpy,
Just educating myself - and planning more ways of spending money!
Gordon
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
RGB2015
Sep 20, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
