ati in-line pump
Old Apr 24, 2003 | 06:40 PM
Kandied91z's Avatar
ati in-line pump
anyone ever have problems with their pump not working?
mine has perfect connections yet seemed to go in and out at times. it's less than 2 years old as well.
Old Apr 25, 2003 | 10:34 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Hey hows it going? check your connections especially the grounds, sometimes if the wiring had a loose connection heat will build up and the relay will "cycle". you are the one with the chromed factory modulars right? the pics Ive seen of your car here before (in appearance and detailing?) look way nicer than those on your car domains site.
Old Apr 25, 2003 | 02:21 PM
Kandied91z's Avatar
well it's not working the way it should so i pulled it, now the in-tank pump isn't supporting either..........i think that the in-tank pump burnt out trying to push the the ati when it wasn't working.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
